Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 8:40 pm)
the docked one - which you're showing, requires Flash. Since you're using Poser (a 32bit program) in a 64-bit Windows environment, you might need the 32-bit Flash as well.
the undocked / external window one requires Air, this can be set for in Preferences. Same 32/64bit story then. But I'm not sure if that's Poser Pro only.
Perhaps this helps, my 2ct. And indeed, get the latest SR available.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
I'm using Windows 7 64-bit, on an Intel i7 2.67GHz CPU and an NVidia GeForce GTX660 graphics card.
The screenshot included should hopefully make it clear what I'm up against. Any advice or recommendations would be gratefully received.
