Fri, Nov 22, 4:23 PM CST
Subject: U/V Scaling doesnt show in rendered scene
Riddokun ( ) posted Wed, 18 June 2014 at 10:02 AM · edited Fri, 22 November 2024 at 4:10 PM
Hello
I had a poser break for some years and I'm finally trying to get back in. For an experiment of mine I wanted to test some really basic options from material room, lets say for example the U and V scaling of a 2d texture that is also tiled.
when i adjust the U or V scale parameters, the changes are correctly displaying in preview window. But when i render the scene, the textured item always appear as with 1x1 scaled tiled texture.
Do i miss something or did something wrong ? or is there an issue here ? (using poser 8 and 10 gave out same problem on render)
Thank you a lot for any help, folks
willyb53 ( ) posted Wed, 18 June 2014 at 10:13 AM
auto fit is checked  :D
Bill
Riddokun ( ) posted Wed, 18 June 2014 at 10:18 AM
Ohhh ! my bad, sorry for such stupid question... I mostly used P4 until i took my poser break... advanced material room is a whole new land to explore :)
i didnt think autofit was in question as the preview was behaving correctly. I just tried to uncheck it and it is working.
Thank you a lot
willyb53 ( ) posted Wed, 18 June 2014 at 10:22 AM
np. auto fit and tile are basicly incompatable
Bill
bagginsbill ( ) posted Wed, 18 June 2014 at 1:43 PM · edited Wed, 18 June 2014 at 1:43 PM
Quote - i didnt think autofit was in question as the preview was behaving correctly
SM wrote the preview engine using a different person and it does not know the rules - at all.
Another common mistake of preview is it always uses global coordinates even when that option A) does not exist or B) is turned off.
aRtBee ( ) posted Wed, 18 June 2014 at 3:05 PM
hi,
http://www.book.artbeeweb.nl/?book=material-room will take you to the promised land...
Riddokun ( ) posted Thu, 19 June 2014 at 7:16 AM
thank you, now i have much reading to feed on... gosh, i feel as noob as i was when i first stepped into poser years ago...
