Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 2:40 pm)
where are you saving the file to? Do you have sufficient permissions to save to that location?
strongly suggest saving individual frames then convert/compile result to suitable movie format. That way if there is a glitch at say the last frame you still have all the other frames and maybe only need to re-render the last frame.
Hi.
In general animations are rendered to sequences of frames. That's how studios like Pixar do it and for good reasons. It's easier to replace range of frames and lengthy rendererings don't rinsk to be lost, like you experienced. Movie clips should be avoided.
Cheers.
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+:
https://plus.google.com/106625816153304163119
The
Reality Gallery: https://reality-plug-in.deviantart.com
I am using 64-bit Poser Pro 2014 (latest updates applied) on a 64-bit Windows 8.1 OS machine with core i7 processor and 16GB RAM.
I try to render a movie of a simple rotating prop for iPhone5 format, but the render hangs at the last frame (frame number 20).
Is there something else I need to prep my movie settings with, in order to avoid this hanging on the last frame ?
(cross-posting to RDNA forum on Animation)
Eternal Hobbyist
