DAZ|Studio F.A.Q (Last Updated: 2024 Oct 21 9:46 pm)
There probably is some error message in the log file about some shader parameter missing. When you do a render DAZ compiles the shaders needed for your design to prepare them for 3Delight. There appears to be some bug with the AoA shader and DAZ not recompiling the shader when it should be.
If you are on a PC, you can go to the directory:
C:/Users//AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard
Delete all the files in that directory and re-render.
If that does not work then save the scene, exist DAZ Studio. Use the task manager to make sure the DAZ Studio process has exited. Then load the scene up again and re-render.
Usually deleting the files in the brickyard directory works for me.
In DAZ Studio 4,6. with some genesis 2 female character and materials the render is all white for the gen body (see picture)
May be some parameters must be changed but i don'T know which
Some suggestions??
Thanks
