Sun, Feb 2, 10:36 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Subject: Having problems with textures not loading
gohanf22 ( ) posted Mon, 21 July 2014 at 6:42 PM · edited Mon, 27 January 2025 at 12:48 AM
Anyone having any problems with Poser 10 lately with it not loading textures at all? When I try to load clothing onto one of my models and then change the texture it disappears.  Like the texture turns it invisible, but when I put the default texture back, it comes back.  Anyone know what is going on?
fictionalbookshelf ( ) posted Tue, 22 July 2014 at 7:31 AM
Is this happening on all things you try to add a texture to or something in particular? I have Poser 10 and haven't had that problem.
It maybe that it is adding the texture but you can't see it until you render the image.
My Store & My Freebies
hborre ( ) posted Tue, 22 July 2014 at 8:43 AM
On the preview window, llittle arrow on the upper right, open the context menu and try reload textures command.  If that doesn't work, open the material room, advanced tab and check if the new textures are loading in at all.  There are 2 possibilities, search feature in General Preferences is not deep enough, but that may give you a texture not found error, or there might be a conflict with a similarly named texture file in the runtime.
