Forum Moderators: wheatpenny, RedPhantom Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2025 Jan 20 4:47 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered. Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Attached Link: High Detail Wood Plane (.MAX Version)
The native 3dsmax (.max) version of this model is now available for download in Freestuff. The .max scene file includes the model, fully mapped with standard shaders and textures, staged in a very simple, 3-point lighting environment, which is "ready to render" using the basic Scanline render engine. Compatible with 3dsmax 2012 or higher.______________________________________
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
Attached Link: High Detail Wood Plane (OBJ Version)
(*Click Image To Enlarge*)A highly detailed, realistic model of a wood plane, also known as a hand plane. The object consists of just 23,256 total polygons, and 23,442 verts; ideal for high polygon, detailed rendering. All parts were modeled separately, and have been carefully UV unwrapped by hand, with special attention given to island placement. The model comes with all the necessary texture maps for color (diffuse), specular (reflection), glossy (blurry reflection), bump, and normals channels. The UV Template map is also included.
The texture maps were hand-painted in several layers for extreme detail at 4096x4096 pixel resolution, and hold up even under the most demanding camera angles and close-up shots. The object contains separate material zones, which can also accept any procedural or seamless texture you wish to use.
Click Here to download the .OBJ Version of this model in Renderosity Freestuff. The native .max version will be available soon.
Alternatively, you can also find and download this model from the following resource locations, including additional renders and wire-frame previews:
Turbosquid.com
ShareCG.com
As always, you are free to use and modify this model for your own renders as you see fit, for both commercial and non-commercial projects. You may not, however, re-distribute this model or textures in part or whole, on their own, or as part of a package/set.
OBJ USERS: Please refer to the included README.TXT file for detailed instructions on how to import this model into your own application or scenes. The obj version comes complete with several specially scaled versions of the model, for use in specific applications, like Blender, DazStudio or Poser.
My Free Models
My Video Tutorials
My CG Animations
