Fri, Nov 22, 1:14 PM CST
Renderosity Forums / Freestuff
Welcome to the Freestuff Forum
Forum Moderators: wheatpenny, RedPhantom Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2024 Nov 17 8:21 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all  freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered.  Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Free Stuff Guidelines
Subject: Freebies: Rigged "Sunrise Cocktail" 3d prop and other free rigged plants
dreamcutter ( ) posted Sun, 03 August 2014 at 1:09 PM · edited Fri, 22 November 2024 at 1:11 PM
Attached Link: Sunrise Cocktail and other free rigged 3d plants at the C3D Plant Exchange
Have a tall cool one, on me!
The Dream Cutter Sunrise Cocktail a 3d Plant Factory animated beverage prop made for Vue 3D, and exportable to other rendering apps via the free Plant Factory Exporter utility. Features export optimized textures and 6 animation presets/parameter controls included to allow full animation. You can simulate a bar tender’s preparation and drinker’s consumption using this single versatile rigged prop:
Features include parameters and presets to Umbrella open/close & scale,
Orange slice rotate & scale, Adjust Beverage level.
Its completely free for private use (including render contests) if used within limits specified in the E-On Software Plant Factory EULA. Contact Cornucopia3d.com for inquires for commercial use. Modelled by Dream Cutter 3d. 151K polygons.
Download free the Cocktail and other rigged plants at the Plant Factory Exchange: http://www.cornucopia3d.com/whats_what.php?crit=Exchange%20Area
I recommend the free TPF Exporter to export as OBJ or FBX (rigging intact) with the free http://www.plantfactory-tech.com/exporter.php
Freebie: 3d rigged Sunrise Coocktail
Alisa ( ) posted Sun, 03 August 2014 at 1:23 PM
Yum!  Thanks :)
Cheers,
Alisa
RETIRED HiveWire 3D QAV Director
Alisa ( ) posted Sun, 03 August 2014 at 1:46 PM
Oh, I thought you could use this with just the free program you mentioned - unless I'm missingsomething you must own Vue to even download this.
Locked to my license(s) : yes
No compatible version of Vue
registered in your account!
So thanks, anyway :)
Cheers,
Alisa
dreamcutter ( ) posted Sun, 03 August 2014 at 11:47 PM · edited Sun, 03 August 2014 at 11:50 PM
Attached Link: Free utility: Standalone Plant Factory Exporter
> Quote - Oh, I thought you could use this with just the free program you mentioned - unless I'm missingsomething you must own Vue to even download this. > > > *Locked to my license(s) : yes* > > ***No compatible version of Vue > registered in your account!*** > > *** > *** > > So thanks, anyway :)
YOU CAN...Especially if your favorite render app like Poser or such supports .OBJ or DS which supports .FBX (rigged) standard formats, then yes this free drink is for you,... and also the neat plants at the Exchange.  What you need to do is use the FREE standalone PLANT FACTORY EXPORTER utility to convert the .TPF to .OBJ or .FBX .  You can download it here http://www.plantfactory-tech.com/exporter.php
From there you can even use the Free Autodesk FBX converter to get a rigged DAE or convert to .x for unity and other game engines.
The rigged cocktail includes some "breeze" animation so unless you desire some sway, you may want to clear the keyframes.  The preset  TPFs allow you to export the various Poses: Umbrella open/close etc as described above.
[EDIT] Saw red note...Crap - I thought you could use the exporter.  Did you try registering that?  I will follow up w/ thier support.   It was my understanding that I could distribute openly via the exchange & exporter.
dreamcutter ( ) posted Mon, 04 August 2014 at 1:33 AM · edited Mon, 04 August 2014 at 1:36 AM
OK I tested the process on a system that does not have Vue.  It downloads fine, but you need to  FIRST download & install the Plant Factort Exporter which is a LITE VERSION OF Plant Factory that allows you to download the exchange items and export to FBX and OBJ.  The registration of the Exporter is all you need to access any of the Exchange items.
Seems convoluted but its kind neat how the Exporter is implemented, actually.
UVDan ( ) posted Mon, 04 August 2014 at 9:40 AM
Forum Moderator
Thanks for staying on top of aproctor's concerns dreamcutter.
