Quote - Hi all,
I am a newbie to Poser and the forum but hope to be active on here. I have one question though, I am unable to locate a male scuba diver. I did find something called PitterBill ??? but Im after a normal build fella with the aqualung, fins and goggles. Can anyone please point me in the right direction. Thanks
Dave
If you are searching for a completely rigged model with SCUBA gear already attached, you may not have too much luck. Michael 4 and Victoria 4 have separate complete diving gear over @ DAZ3D. I believe there are a few other props available, but it has been some years since I seen those.
Attached Link: Free Stuff Search Results: Diving
> Quote - Go to the frestuff area on this site and do a search for "diving" , > > maybe some of those items suits your needs.Attached Link: http://larashots.com/appleyard/3d/3d.htm
as jonnybode says, plus try the link above. This site has loads of diving stuff. As with any poser prop or figure you'll have to attach it to your figure. General the way to do it is load your base figure first, say V4 and Pose it. Then - in the same scene- load the clothing you want as a seperate figure, select it, and click confirm to. In the list select your base figure, which is usually figure 1. OK it. You might need to adjust the clothing a little with the dials in the areas where stuff poke-through or postwork it out. After that loads your props - usually things that don't have moving bits - and use the dials to move each one into position. It's a little fiddly - and takes time - but with practice you'll get used to it.Pinky - you left the lens cap of your mind on again.
Hello daibeer & welcome to the asylum :)
#1 Rule have fun !
#2 Rule have more fun !!!
Fell free to ask any question at all.
Getting started we all need help.
it helps to say witch charater ya need stuff for and what version of Poser ya using.
when needing stuff.
So it would be I need scuba diver gear
for Dork ,Poser 4 or for Rex ,Pro 14
or what ever your using :)
The
Artist that will fight for decades to conquer their media.
Guessing it's a prop here :) If so you need to parent the prop to the right body part. Select the prop and double click on it. Select Properties. Click the button that says "set parent" select the body part you want to "glue" the prop to. Say for example the fin is the lower left arm, you'd select Left Foream. OK it a couple of times. Now when you move the figure (without touching the prop) the prop will move along with the figure. Another way is select the prop, and without clicking on anything else in the scene window, in the "Object" menu select Properties. If the fin is a figure you'll need to conform it.
Hi all,
Dave
