Thu, Nov 7, 4:42 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 05 9:36 pm)
Subject: Would anyone like this hair?
Believable3D ( ) posted Sun, 10 August 2014 at 8:18 PM · edited Thu, 07 November 2024 at 4:42 AM
I'm contemplating the possibility of putting together a bundle of dynamic hair, and as sort of a warmup I've put this together. It's a semi-Goth style: very short on the sides and long and pulled back on top. It's far from perfect, but if anyone thinks it may have its uses, I'll figure out how to bundle it and offer as a freebie.
______________
Sa_raneth ( ) posted Sun, 10 August 2014 at 9:10 PM
i like it and could  use it
3D-Mobster ( ) posted Sun, 10 August 2014 at 9:36 PM
Thats not bad, I try the hair room once in a while, but always give up, i really dont get the controls and my hair always looks bad, so i give up quite fast. :D
Really hope they make some serious improvements to that room. Maybe so you could create single lines that you can use to control hair within a set range so it was possible to get the hair to flow like you wanted a bit more easy.
Believable3D ( ) posted Sun, 10 August 2014 at 10:32 PM
Thanks, guys. I've uploaded the package and it's waiting approval. When it's available, please do let me know if I have any packaging (or other) errors. It's looks to be a simple process, but perhaps I overlooked something.
______________
Cage ( ) posted Sun, 10 August 2014 at 10:36 PM · edited Sun, 10 August 2014 at 10:37 PM
That looks very effective.  I like the stubble on the sides.
Some time in 1992, I found myself in a room full of kids (ah, we were all kids, then) with that basic hairstyle.  One of them looked around and noted that, in a group of people who saw themselves as rebels, it was rather interesting that everyone had the same haircut.  :lol:  I wanted to point out that I wasn't much of a rebel, more a fan of the cartoons of Jaime Hernandez.  With my hair texture, I rather looked like Bizarro Bozo the Clown, with that sort of cut.
Umm.  :unsure:  I... like the stubble on the sides.  It would be interesting to study how you've structured this hair.
Believable3D ( ) posted Sun, 10 August 2014 at 10:38 PM
I'm guessing someone may have fun making the top/center part black and the sides bright red or something. :p
I packaged it all as blonde, but I also included about 15 other hair materials that I've been working on.
______________
Believable3D ( ) posted Sun, 10 August 2014 at 10:42 PM · edited Sun, 10 August 2014 at 10:43 PM
Quote - I... like the stubble on the sides.  It would be interesting to study how you've structured this hair.
It's really pretty basic. [Edit: Only three groups: top, and two sides.] The top is pulled back, and the sides are short and pulled slightly down and back.
I realize now I could have turned down the verts per hair on the sides. I left them at the default (20). The long hair is 50. I also have pretty high density, so obviously, it's a bit of a resource hog. Some users will want to turn down some settings.
______________
ockham ( ) posted Mon, 11 August 2014 at 5:53 AM
I like it.  Straight out of 1958.  Bobbysox, poodle skirts, Bobby Darin, Hot-rod Lincoln!
My python page
My ShareCG freebies
RedPhantom ( ) posted Mon, 11 August 2014 at 6:02 AM
Site Admin
I could see me using this. Thanks
parkdalegardener ( ) posted Mon, 11 August 2014 at 7:15 AM
Commander Cody and His Lost Planet Airmen did a great cover of that tune.
quietrob ( ) posted Mon, 11 August 2014 at 8:58 AM
Quote - > Quote - I... like the stubble on the sides.  It would be interesting to study how you've structured this hair.
...I realize now I could have turned down the verts per hair on the sides. I left them at the default (20). The long hair is 50. I also have pretty high density, so obviously, it's a bit of a resource hog. Some users will want to turn down some settings.
I like the hair but I want to try out changing the settings so it's not quite the resource hog.  Is the hair at your site?
Miss Nancy ( ) posted Mon, 11 August 2014 at 1:47 PM
yes, it's very nice!
Believable3D ( ) posted Mon, 11 August 2014 at 2:59 PM
Okay, it was approved for the freestuff section. You can find it here: http://www.renderosity.com/mod/freestuff/?item_id=74229
______________
Believable3D ( ) posted Mon, 11 August 2014 at 3:03 PM
At high hair density there are a few loose strands that didn't settle down. If you need to render the back, you may want to run a short sim to get it to settle. If you lower the density and use thicker hair instead you probably won't have the issue (I don't think any of the guide hairs are sticking out like this), but for myself I prefer the realism of the current settings.
______________
Sa_raneth ( ) posted Mon, 11 August 2014 at 3:15 PM
got it  thank you
RedPhantom ( ) posted Mon, 11 August 2014 at 4:44 PM · edited Mon, 11 August 2014 at 4:46 PM
Site Admin
The reason for the stray hair is that you have several stran guides that are much shorter than the rest of the group. If you drasitcally change length of guides, poser has trouble filling in the in between hairs.
Believable3D ( ) posted Mon, 11 August 2014 at 4:46 PM
Thanks for the tip!
______________
Believable3D ( ) posted Mon, 11 August 2014 at 4:47 PM
I guess if I had made them just long enough to curl down, I wouldn't have those strays.
______________
phil_lawson ( ) posted Wed, 20 August 2014 at 9:02 AM
I'm as bald as a coot so I'd like any hair.. Oh, hang on, I see what you're getting at..
