Sat, Jan 25, 4:14 PM CST
Subject: Wardrobe Wizard P6 to P5 conversion
hamiltonpl ( ) posted Mon, 11 August 2014 at 4:04 PM · edited Sat, 25 January 2025 at 4:13 PM
I have a P6 James Flightsuit that I want to convert to a P5 Don.
I have Poser Pro 2012 with Wardrobe Wizard.  I've run the conversion before with Poser 7 and the older WW that results in a converted clothing prop that is lined up along the legs and arms properly when conformed.  Althought the props needs considerable smoothing.
However, when I use the PP 2012 and WW, this flight suite will NOT line up with the arms - the arms of the suit are at "neck level" and to the front of Don P5. Also, I tried to convert to Simon P7 with the same result.  The arms are not lining up and no amount of shifting can correct it properly.
Ideas on what I might be doing wrong or is there another way to correct this?  I have duplicated the problem on two separate installs of PP 2012.  Both on Windows 7.
Windows 10 - Poser Pro 2012 - 64Bit - 24GB RAM - 4 x 3.40 GHZ processor
PhilC ( ) posted Mon, 11 August 2014 at 11:24 PM
Could you please post the following screen shots.
Load P6 James and the flight suite. Do not conform but fully zero both figures.
The Wardrobe Wizard conversion window showing your selections, options etc.
P5 Don and the converted flight suit. Do not conform but fully zero both figures.
As (3) but conformed.
When zeroing a figure ensure that absolutly everything is zeroed, translations, rotations, scaling (100%), morphs. Later versions of Poser have the menu option Figure > Zero Figure. Or use the Wardrobe Wizard "Zero Figure" button.
Thanks.
hamiltonpl ( ) posted Tue, 12 August 2014 at 11:19 PM
Mr. Cooke - I have sent you these pics via email.  Let me know that you received them. Also, I attached the flightsuit file I am working with in case you don't already have it.
Thanks for your help.  phil
hamiltonpl ( ) posted Tue, 12 August 2014 at 11:22 PM
Here us the suit lined up on James.
hamiltonpl ( ) posted Tue, 12 August 2014 at 11:23 PM
Here are my settings.
hamiltonpl ( ) posted Tue, 12 August 2014 at 11:23 PM · edited Tue, 12 August 2014 at 11:24 PM
Here's the converted unconformed FlightSuit on P5 Don
hamiltonpl ( ) posted Tue, 12 August 2014 at 11:25 PM
And finally the conformed suit and it doesn't change. Still the arms are off and to the front.
PhilC ( ) posted Wed, 13 August 2014 at 12:22 PM
"Here us the suit lined up on James."
Is the suite lined up on James or is the unconformed suite at the fully zero pose?
There are two versions of the James figure, "James" and "JamesG2". They are very similar except that the arm positions are different in the zero pose. I suspect that the suit was made for other version of James to the one that you show in your screen shots.
hamiltonpl ( ) posted Wed, 13 August 2014 at 3:15 PM
In picture 1, the suit is ZERO'd like the figure and unconformed.  So, it would appear that suit would in fact line up - or is supposed to.
Shoud I use the James Hires as the FROM side?
PhilC ( ) posted Thu, 14 August 2014 at 3:36 AM
Yes but which figure is it, Poser 6 James or JamesG2? In the Wardrobe Wizard GUI you have selected the "from" figure to be P6 James which would be correct if it is the Poser 6 version of James in the scene. If not then you will see the effects you are observing.
If you find that you should have selected the G2 version of James in the Wardrobe Wizard GUI be sure to select the "Force reanalyses" option when you reconvert. If you do not then it will simply reuse the old incorrect data and you'll get the same result as before.
hamiltonpl ( ) posted Fri, 15 August 2014 at 3:03 PM · edited Fri, 15 August 2014 at 3:04 PM
Okay after getting my window back in confirmed that I had a new analysis file for PW James flight suit.
 I chose the JamesG2 Basic FROM character and I am getting the same result.
 Is there any way to perform a reanalysis of the JAMES that comes with Poser Pro 2012?  The flight suit fits that character perfectly.  I dont have any other version of James and am wondering if the data files provided in PP2012 are for a different version??
 I know that in the old WW you would load the character you wanted to convert from and a new file would be created from that character.
 Any way to get this version to recreate a new file from the James that I have?
PhilC ( ) posted Fri, 15 August 2014 at 3:40 PM
What OBJ file does your James use?
hamiltonpl ( ) posted Fri, 15 August 2014 at 5:00 PM
In Poser Pro 2012 there is no James OBJ but there are these:
PhilC ( ) posted Fri, 15 August 2014 at 7:58 PM
OBZ is the Poser compressed form of the OBJ file format.
You show the Poser 6 James folder however JamesG2 is not listed. I wanted to be absolutly certain which version you were using but sadly at this point I still can not be. I do know that if the wrong one is used you will get the error that you are observing.
Is the suite a legitamate freebie that I could legally download and convert for myself? At this point I think that is the only way I can show you, step by step how to proceed.
hamiltonpl ( ) posted Fri, 15 August 2014 at 11:24 PM
I sent it to you in a email when I posted the pics  - I got it from Poserworld a few years back. Do you have the email?
PhilC ( ) posted Sun, 17 August 2014 at 6:05 AM
For me to be able to answer your question I need to know with absolute certaintly:-
  1. What figure the costume was originally made for.
  2. That the chosen "from" figure is the figure that the costume was originally made for.
So far I do not have that information.
I do not think that your end user licence will allow you to send me the costume files. You have already sent me the costume CR2 file however that does not tell me which figure it was made for.
I have tried to answer your question and have indicated that if the wrong figure is chosen then you will get the errors you are seeing. I'm not sure what you have done regarding reanalyses. I feel that my only option left is to perform the conversion here and then show you what I did via screen shots. This would involve me in purchasing a subscription to Poser World which is something that I prefer not to do.
How would you like me to proceed?
hamiltonpl ( ) posted Sun, 17 August 2014 at 10:02 PM
Philc thanks for all of your help.  I have no idea which figure the flight suit was made for.   But even if I did not know - seems like I could through trail and error select each of the JAMES "Froms" in WW.  So far they all produce the same result - misalignment at the arms.  :/
So, what is strange is how well it aligns with the JAMES that comes with PP2012 which is not G2.
I can use the suit I converted with Poser 7 and WW originally, I was hoping that I might get a better conversion with the new versions.
Thanks for all of our help and persistence on this.  ph
