Sun, Feb 2, 2:00 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Subject: Poser 9 Firefly render with HDRI and AO - what's causing the 'banding'
3dcheapskate ( ) posted Mon, 25 August 2014 at 11:08 AM · edited Sun, 02 February 2025 at 2:00 PM
Partial render attached. What's causing the horizontal banding?
Scene contains two lights with intensities cranked up high:
  • Diffuse IBL, 180% intensity, IBLcontrast 0.5, using the free sIBL 'Topanga Forest' HDR image (converted from lat/long to angular(light-probe) in HDRShop), no shadows, AO enabled (strength 1.0)
  • Infinite light, 200% intensity, depth mapped shadows, AO enabled (strength 1.0)
Scene AO settings: max dist 1.0, bias 0.0002, samples 3, evaluate in light UNchecked
(My units are Poser Units)
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
3dcheapskate ( ) posted Mon, 25 August 2014 at 11:13 AM
Render settings
3dcheapskate ( ) posted Mon, 25 August 2014 at 11:17 AM
IBL/AO settings
3dcheapskate ( ) posted Mon, 25 August 2014 at 11:20 AM · edited Mon, 25 August 2014 at 11:23 AM
The dragons skin has no texture or shader network applied, and the banding still appears (just above its left foreleg, so I assume it's nothing to do with the textures.
I'm 99% certain it's something to do with my AO settings. I often get weird shadowing along mesh lines (which usually indicates that I need to increase the AO bias), but I've never seen anything like this before.
DarwinsMishap ( ) posted Mon, 25 August 2014 at 11:39 AM
I rarely use AO, since P10 doesn't need it- unless it's in a seperate rendering pass.  I'm fairly certain as well it's the settings...
Why are your lights set so high, might I ask?
kalrua ( ) posted Mon, 25 August 2014 at 11:48 AM
Irradiance catching 32
Irradiace catching 100
Ao Sample 9
3dcheapskate ( ) posted Mon, 25 August 2014 at 8:56 PM · edited Mon, 25 August 2014 at 8:57 PM
Quote - I rarely use AO, since P10 doesn't need it- unless it's in a seperate rendering pass.  I'm fairly certain as well it's the settings... Why are your lights set so high, might I ask?
The 180% for the IBL is based on this http://poser.smithmicro.com/tutorials/poser_IBL.html (I don't use HDR that much, so 180% intensity + 0.5 contrast seems a good start). The infinite was originally at 50%, but this was far too low compared to the IBL intensity, so I wound it up to 75%, 100%, 150% and ended up at 200%. I'll try dialling down
kalrua: That could be it - the effect in the first image looks sort-of similar, with distinct horizontal lines. I'll try increasing the irradiance catching.
(Alternative option: try using IDL instead of the diffuse IBL...)
3dcheapskate ( ) posted Mon, 25 August 2014 at 9:20 PM · edited Mon, 25 August 2014 at 9:21 PM
Yep, increasing irradiance catching from 32 to 100 completely got rid of the banding (I only re-rendered two small rectangles to check - see the attached image ).
Many thanks.
