Mon, Dec 23, 1:36 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 23 1:20 pm)
Subject: Visible Glowing Lights
Connatic ( ) posted Fri, 29 August 2014 at 5:00 PM · edited Mon, 23 December 2024 at 1:35 PM
I was experimenting with Atmosphere and Light-sources after reading a few threads about the subject.  I got a good visible light by using:
Atmosphere - Volume On
volume density = 0.01
volume stepsize = 0.175
The light settings are in the pic.
When I attached Edge Blend to the light Diffuse it made a very interesting effect. Attaching it also to Color makes it even stronger.
piersyf ( ) posted Fri, 29 August 2014 at 5:26 PM
Nice effect.... thanks for sharing!
seachnasaigh ( ) posted Fri, 29 August 2014 at 10:44 PM
     I'd never seen that done with a point light - good work, Connatic.
     My first thought is whether the light cast can be adjusted relative to the glow brightness.  The light cast onto the floor looks overly bright compared to the pink pixie-like ball of light.  This is well worth pursuing;  I like the effect.  👍
Connatic ( ) posted Fri, 29 August 2014 at 11:00 PM
The cast glow can indeed be adjusted to change the relativity.  There are the atmosphere settings on the light and the actual atmosphere itself.  As I experimented I could see the ratio change as I tried different settings.  I did not do it enough to recall what yielded the proper balance, but I am sure it can be done.  The Attenuation setting on the Edge Blend has a big effect on the balance of the 2 colors added to the light.
I also narrowed the spotlight and it became a tight beam.
Atmosphere also has a Volume Noise which has major effect on this.
Connatic ( ) posted Fri, 29 August 2014 at 11:25 PM · edited Fri, 29 August 2014 at 11:31 PM
It looks a lot more balance with these settings (I use units=feet):
Atmosphere:
Vol Color = pure white
V Density = 0.022
V Stepsize = 0.133
V Noise = 0.13
Point Light:
Attenuation = Inverse Square
Atm Str = 0.07
Intensity = 0.05
Edge Blend Att = 0.3
The Atmosphere Noise only works in conjunction with larger Volume Stepsize settings.
Connatic ( ) posted Fri, 29 August 2014 at 11:42 PM
Here is a render using the above settings.
3dcheapskate ( ) posted Sat, 30 August 2014 at 2:22 AM · edited Sat, 30 August 2014 at 2:31 AM
I'd seen that sort of effect in a couple of renders (e.g. Lenny2's "Jewel" and the 'no postwork comment convinced me it had been done using atmosphere). My own attempt ("Will O'The Wisp" - mild nudity warning)  fell a bit short of the mark and needed postwork. Your last picture above is exactly what I wanted... but in green/yellow.  Thanks for the information on how you did it (using the edge blend seems a great touch!) - I need to fish out the scene file and try using your settings.  :)
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
rokket ( ) posted Sat, 30 August 2014 at 5:56 PM
I am missing something, and it's how you are applying the atmosphere. When I apply the settings you posted, I am not seeing the same effect...
Connatic ( ) posted Sat, 30 August 2014 at 6:12 PM
@rokket - My first guess would be that your UNITS in prefs is not set to feet.
rokket ( ) posted Sat, 30 August 2014 at 6:15 PM
No, I changed it when you noted that. What I am trying to find out is how you applied the atmosphere. Did you just go into that tab in the materials room and make those changes or did you apply it via the WACROS?
Connatic ( ) posted Sat, 30 August 2014 at 6:44 PM
I did not use any wacros.  Just check Volume On in the Atmosphere Mat Tab and enter the settings.
I also did not use Gamma Correction in the Render Settings.  I recall it diminished the effect quite a bit.  I need to experiment with that a bit more.
rokket ( ) posted Sat, 30 August 2014 at 6:46 PM
I am using Poser 9, so no GC for me. But what about IDL?
Connatic ( ) posted Sat, 30 August 2014 at 6:54 PM
I was not using IDL.  It works when using it, but it adds a lot more illumination, so the ratios between the Glow and the Illumination would need to be adjusted.
I have found a few other interesting ways to alter the glow and the illumination.  I will add to this very soon.
Connatic ( ) posted Sat, 30 August 2014 at 6:56 PM
Oh, there is one more important condition!!!!!  The light itself MUST be in front of something!
It will not show up over the empty Background.
rokket ( ) posted Sat, 30 August 2014 at 6:57 PM
Ok, that gives me a pretty good starting point.
I will play with it. I'll check back later to see what you have come up with.
rokket ( ) posted Sat, 30 August 2014 at 6:59 PM
Quote - Oh, there is one more important condition!!!!!  The light itself MUST be in front of something!
BB's Envirosphere? Or maybe a single sided square with visible in camera unchecked?
Connatic ( ) posted Sat, 30 August 2014 at 7:04 PM
I simply had my light aligned in front of the ground.  You can see where it cuts off at the horizon.
Just do what I did, or put a box or any mesh behind the light.  The atmosphere does not show up over background.
rokket ( ) posted Sat, 30 August 2014 at 7:16 PM
Got it. Thanks a lot.
rokket ( ) posted Sat, 30 August 2014 at 8:41 PM
Cool! Thanks again for posting this. I can't wait to see what else you are doing with it!
Connatic ( ) posted Sat, 30 August 2014 at 8:46 PM
Nice pic!
rokket ( ) posted Sat, 30 August 2014 at 8:50 PM
It was the result of your work. I just copied what you did. I added a prop wall behind her to catch the atmosphere and make the whole effect work. Trying it with a single sided square near her hand wasn't cutting it.
3dcheapskate ( ) posted Sun, 31 August 2014 at 2:06 AM
:biggrin: I found my original PZ3 and tried Connatic's 'more balanced' settings - that's *much* more like what I was after, (although obviously too bright - the point light in this scene was very close to her face). Next step, trying to get the balance right between the glow and the cast light...
Thanks again for those settings, and the edge blend idea!
(P.S. Poser 9 render, Auto/Final quality, no other lights, backdrop was plugged into ambient on one of the DAZ environment props)
3dcheapskate ( ) posted Sun, 31 August 2014 at 2:44 AM · edited Sun, 31 August 2014 at 2:45 AM
I've got what I was after now. There's probably many different ways to balance things, but reducing light intensity from 0.05 (5%) to 0.02 and changing the edge blend inner color to 192,192,192 (and outer to bright green) look good to me.
I had some problems because my point light was directly in front of her arm. I tried changing various things without success, and eventually side-stepped the problem by simply moving the light!
Once again, thanks for the great tip Connatic!
rokket ( ) posted Sun, 31 August 2014 at 7:37 AM
That looks really good! I posted a 1920x1080 render of mine in the gallery.
3dcheapskate ( ) posted Mon, 01 September 2014 at 12:51 AM
Quote - That looks really good! I posted a 1920x1080 render of mine in the gallery.
Great image - I'm no expert, but a good lighting setup (and I'd now say that a single point plus Connatic's volume settings is a good setup) can work wonders with even the most simple image - somebody's already made a similar comment on your picture!
rokket ( ) posted Mon, 01 September 2014 at 2:14 AM
I am amazed at how much high praise it has gotten, considering every other image I put in there might get 2 comments, but no ratings, no favorites. It says a lot about the lighting. Way to go Connatic!
piersyf ( ) posted Mon, 01 September 2014 at 5:51 AM
Anybody that comes up with an innovative use of Poser lighting is likely to attract as much attention as someone that can use python (Snarlygribbly) or the materials room (Bagginsbill). I can see Believable3d becoming the hair room guru at some point (although for me, not quite there yet).
