Are you in OpenGL mode or Sree? How are you conforming the hair to Justin? Have you rendered and still see the same problem? I have loaded the G2M into my stage and conformed the Brit hair to his head by clicking & dragging the hair to the model. I've even scaled G2M to 25% and the hair remains completely conformed without any stray hair. Give us more info on the workflow; so far I haven't seen anything unusual on my setup.
I am a amateur user of Poser 2014
I have just started to use Genesis content.
I have install DSON and Genesis Starter essentials.
My problem is that when I try use Brit hair with teen Justin some of the hair is sticking through is eyebrow area.
See screenshot attached
I am sure all the content was installed OK with CF files
I have tried to adjust but am unable to get rid of these
I have tried conform to Genesis figure
I have used the DSON transfer morphs script
All to no avail
Is there a way I can fix this such as making the sections of hair invisible
Such as selecting the polygons and making them invisible
Step by step approach appreciated.
Many thanks in advance
