Mon, Feb 3, 2:10 PM CST
Subject: Can't select prop or figure
nabob21 ( ) posted Sat, 20 September 2014 at 2:54 PM · edited Sun, 26 January 2025 at 6:26 AM
Online Now!
Hello everyone,
I have a question about a problem I am having with some free props and figures I am getting from a couple of sites. These props and figures are Poser compatable and load into the scene okay, but I can't seem to select them to move them or activate the parameter dials. Has anyone else had these issues? It seems rather strange. It is almost like Poser doesn't see them even though it just loaded them. I am using Poser Pro 2012 with the latest service release.
Thanks for your time and any replies.
nabob21
Ometeotl ( ) posted Sun, 21 September 2014 at 6:16 AM
Yes, I encountered this problem a couple of times, too. Either in Poser 8 and Poser 9. Never found a solution for the problem. I think the problem lies somewhere in .obj-file, because even after I imported the obj I wasn't able to select the items.
rokket ( ) posted Sun, 21 September 2014 at 11:30 PM
I've heard of this problem happening with things off certain sites. Sites which are not exactly, uh.... doing legit business if you catch my drift.
Ometeotl ( ) posted Mon, 22 September 2014 at 8:33 AM
I've got the last item with this problem from ShareCG.
It was one of a series of SciFi-objects, some of them made on requests.
So you can drift every which way you want, rokket, but this problem doesn't seem connected with the legal status of the download.
rokket ( ) posted Mon, 22 September 2014 at 8:04 PM
Quote - I've got the last item with this problem from ShareCG.
I am not suggesting you knowingly downloaded something illegal, so if I come off that way, I apologize. It's just that others have posted problems like this and the end result was that they got the prop or figure from a site that members on here know to be one that literally steals from others and passes them off as their own. Even selling stuff that people put up here as freebies.
Since that doesn't seem to be the case with you, I'd suggest uninstall it and reinstall and see what happens.
Ometeotl ( ) posted Tue, 23 September 2014 at 1:36 AM
None offence taken, so there's no need to apologize.
And I've tried everything I could think of. Re-installed, re-downloaded, loaded it in P8 and in P9. I even skipped using the poser-prop and imported the .obj directly into Poser. When even this failed, I concluded that the flaw must be in the mesh and gave up.
rokket ( ) posted Tue, 23 September 2014 at 3:30 AM
I am at a loss. I hope someone sees this post and can help.
hborre ( ) posted Tue, 23 September 2014 at 11:06 AM
Online Now!
Has anyone tried loading an established figure first (i.e., V4 or other) than importing the obj?  I see no posting of this attempt and I am curious if it is an actual mesh problem or the program having issues.  I would go further to suggest importing an object that should work and trying to manipulate it.
nabob21 ( ) posted Wed, 24 September 2014 at 8:30 PM · edited Wed, 24 September 2014 at 8:31 PM
Online Now!
Thanks everyone for your replies.
It sounds like Ometeotl has the same issue that I am having. The latest prop I am having problems with came from ShareCG as well. I have also tried re-downlaoding the item and tried opening it in Poser Pro 2012 and 2014. All with the same result. I have even tried hborre's suggestion and loaded V4 first with no problems and then the prop but still no luck.
If someone wants to try downloading the item and seeing if they get the same result the item is called the "SteampunkShip Corridor: Moon Pool" by Bad Faerie at ShareCG. I would provide a link but I am not sure if that is allowed. This is just one of a handful of items that give me this issue by different people so it is not something that is just by Bad Faerie. I think I even got some of the non-working props in the Free Stuff section of Rendo.
  • editied for a spelling error*
Latexluv ( ) posted Wed, 24 September 2014 at 9:42 PM
Found it. Downloaded it. Installed it into Poser. Prop is non-functional. I uninstalled it from Poser 10. Don't know what's wrong with it but I suspect that it is because it was first made for Daz Studio and not properly ported out for Poser use.
Weapons of choice:
Miss Nancy ( ) posted Wed, 24 September 2014 at 10:40 PM · edited Wed, 24 September 2014 at 10:53 PM
o.k., I try it to see if can confirm.  will let you know.
no, it don't work in poser.  can't move, edit, spawn props, nor render it.
RedPhantom ( ) posted Thu, 25 September 2014 at 6:12 AM
Site Admin Online Now!
When I tried, I was able to move one ladder. Could not delete the thing from the scene afterwards. Even when I did undo for the load it stayed. When I hit redo I ended up with 2 and both were stuck.
