Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 6:38 am)
It might be that you need to run poser as Administrator (right click on Poser shortcut and select Run as Administrator).
The uncompress probably tries to access folders that Windows considers protected, running in Admin mode should get round that.
John
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
nice one :) You're welcome
in addition, for those in need: you can open the pzz with a unzip utility. It contains the uncompressed Poser file, yet without any extention. Unpack and add the appropriate file extention, and you're fine.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
I'm running PoserPro 2014 ( 64bits) window 7. I tried scripts/utility/uncompressedposerfiles
but it didn't work . the scripts starts and stopped instantly !
Anyone has encountered the sampe problem ? Any clues what's wrong ?
