Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2025 Feb 23 2:34 pm)
Hi Scott! It disappears altogether. I even made a render with just props - an OBJ, a PP2 and a 3DS, just to see what would happen. It looks like it's just this cape that does it. Other 3DS files don't seem to do this. The transparency is set at 0% on it, it's black, no texture applied. I'm gonna end up painting it in free-hand and I'm a bit dodgy at that! :o)
Hi troops! :o) Got a wee problem to pick your brains about... I've been rendering an image with a superhero character wearing a cape. Everything was fine and dandy until the final render in the smaller work window (640x480). Then I thought I should make a larger version (600x800) to make post-work easier. Only problem with this is, whenever I render in a larger window, the cape disappears. Totally. No shades, no vague outline or anything. All other props remain. Some are PP2, some OBJ, and some 3DS. This is the onyl one that disappears. Has anyone else come across this problem before when rendering in different window sizes?
