Poser - OFFICIAL F.A.Q (Last Updated: 2024 Aug 03 7:14 am)
this is only a guess :) I'm not at home right now. The reduction tool has an option to maintain the mesh by material zone. The lips are a single zone at the moment. You could try using thr grouping tool to give one of the lips a different material zone, then run the reduction tool.
You will end up with a new material zone of course, but it should keep the meshes seperate.
John
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
Quote - Why would you reduce Victoria 4? DAZ 3D did the work for you and she comes with a collection of lower resolution meshes. (1K, 2K, 4k and 17k)
(RuntimeGeometriesDAZPeopleblMilWom_v4b_LOD)
In fact you can still apply the morphs to these resolutions.
Yes but can you conform it to the clothing figure?
Quote - > Quote - Why would you reduce Victoria 4? DAZ 3D did the work for you and she comes with a collection of lower resolution meshes. (1K, 2K, 4k and 17k)
You can conform clothing to it. Open up the V4 cr2 in any text editor and replace the geometry lines with the LOD version you need. (In DS it is simply load the LOD onto the base version.) Save as a new name CR2 in the same folder.
