Fri, Nov 22, 10:20 AM CST
Subject: why an out of memory error?
Faery_Light ( ) posted Fri, 03 October 2014 at 2:13 PM · edited Tue, 19 November 2024 at 11:12 PM
I have an optiplex 760 (64bit, duel core), 750gb disk space and 4 gb of memory yet if I try to do a full scene in Bryce 7 I get an out of memory error.
So aggrevated that I had all my mountains in place, my water placed and started adding trees.
All I had was eight trees and when I tried to add another it hung with out of memory.
The, even though I had svaed the scene, after closing and re-opening, there was nothing there!
What gives???
ThunderStone ( ) posted Fri, 03 October 2014 at 6:45 PM
Bryce is a 32-bit software. 32 bits are limited up to the 2 GB in memory. You'll need to get Bryce to see the other memories. You'll need to get Large Address Aware to make Bryce see the rest of the memories.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Faery_Light ( ) posted Fri, 03 October 2014 at 9:34 PM
Thank you. :)
ThunderStone ( ) posted Fri, 03 October 2014 at 10:20 PM
You're welcome :biggrin:
staigermanus ( ) posted Fri, 03 October 2014 at 10:24 PM
Quote - Bryce is a 32-bit software. 32 bits are limited up to the 2 GB in memory. You'll need to get Bryce to see the other memories. You'll need to get Large Address Aware to make Bryce see the rest of the memories.
Indeed with LMA you could get it to about 3.2 GB tops per app. Even though you have 4 GB of Ram, the 32-bit version of Windows only can addres up to around 3.2 GB if memory serves me right. (pun intended)
If you run a 64-bit version of WIndows, even if you have a 32-bit application that's the main memory hog, you still have a bunch of other processes, services and programs with or without a window that are running at the same time. Ever checked all the things that Adobe runs? A bunch of servers. A whole bunch. If you have the suite of various apps that want to talk together.
I recommend at least 8 GB, I use 16GB, and I run PD Howler which is a 32-bit app, and it runs better than if I only had 4 GB because the other apps are not competing with memory that Howler wants. I think Bryce's situation may be similar.
-Philip
Project Dogwaffle at thebest3d.com - beyond digital painting, now at v9.5 with erosion, sediments, volumetric particle clouds and self-shading on foliage brushes.
Mysteral ( ) posted Fri, 03 October 2014 at 10:26 PM
Thanks for the tip ThunderStone.
Instructions for downloading and installing CFF Explorer to enable L.A.W. can be found at http://www.pso-world.com/forums/showthread.php?t=199993
Just sustitute Bryce for PSO-World when setting up.
As a writer, I control the lives of millions. Whole worlds can be destroyed by typing the correct sequence of letters on my keyboard.
Robert A. Read
