Tue, Nov 26, 2:56 AM CST
Subject: Really wish Poser Had!
arrow1 ( ) posted Mon, 27 October 2014 at 5:26 PM · edited Tue, 26 November 2024 at 12:46 AM
I know that this not possible but I really wish that Poser could come up with an animated ocean or sea.I have been trying for over twelve montha to import a WW2 U-Boat animated in Poser Pro 2014 to Vue 11 Infinite.I can get the boat imported and saved as a vob! I then make the sea.No problem! But trying to render 670 fgrames is a nightmare.Something always goes wrong! Vue spent 90 hours rendering using three machines networked via rendercow and all I got was an out of focus animation.I tried a second time and the ocean rendered but not my submarine.Vue also locks up and wants to close down and send an error report.The resources vue requires are enormous.I can render a large scene in Poser in a fraction of the time as vue and get a result.The only problem is Poser enviroments, landscape and seacapes look false.If anyone can come up with an animated ocean or sea for Poser that looks real I shall certainly buy it! Sorry about the rant but I am so frustrated with Vue! Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Jaager ( ) posted Mon, 27 October 2014 at 5:37 PM
Would this work?
Animate the sub in Poser as a series of stills with alpha channel.
Animate the sea in Vue as a series of stills.
Combine the stills in PS or Painter or PSP and convert that to an animation using a conversion program.
arrow1 ( ) posted Mon, 27 October 2014 at 6:44 PM
Many thanks Jaager for your reply.I guess your suggestion might work.How do I add an alpha chanel in Poser? Cheers
arrow1 ( ) posted Mon, 27 October 2014 at 7:18 PM
Got Poser rendering my animated U-Boat 670 image files png"s on a black background.I hope I got this right? Cheers
seachnasaigh ( ) posted Tue, 28 October 2014 at 1:32 AM
Should be PNGs on a transparent background.
arrow1 ( ) posted Tue, 28 October 2014 at 2:49 AM
So I should be rendering on a white backgound.When I looked up importing animated images into photoshop it said to render on a black background.Have I got this wrong? Cheers
seachnasaigh ( ) posted Tue, 28 October 2014 at 3:07 AM · edited Tue, 28 October 2014 at 3:20 AM
You want to render on no background.
     And in Vue, I'd try putting a completely transparent (no specular highlights!) primitive in place for the sub, and use a water material which gives foam near object surfaces.
seachnasaigh ( ) posted Tue, 28 October 2014 at 3:16 AM · edited Tue, 28 October 2014 at 3:21 AM
You want this effect - only the rendered object shows, but without the shadow - and eliminating the shadow can be done by clicking the "eye" icon of the ground plane in the hierarchy panel.
seachnasaigh ( ) posted Tue, 28 October 2014 at 4:57 AM · edited Tue, 28 October 2014 at 4:59 AM
     I told you wrong, Arrow.  In the Appleseed pic, the ground is not visible, but the in the material room, I had the ***shadow_catch only*** box ticked.  To eliminate ground shadow, set the ground as not visible and also make sure that the shadowcatch box is un-ticked.
     Note:  the screenshot shows the ground set up to be visible and catch shadows.
arrow1 ( ) posted Tue, 28 October 2014 at 4:59 AM
seachnasaigh, many thanks for your assistance and patience. I will have to start again! Cheers
arrow1 ( ) posted Tue, 28 October 2014 at 11:47 PM
seachnasaigh, Sorry to be a pain!!! The poser rendering I understand! But the Vue rendering (putting a completely transparent, no specular highlights primitive in place for the sub,and use a water material which gives foam near the object surfaces) I do not understand. Would you mind enlightening me? I have included a still shot from my stormy sea animation! My submarine is also animated and moving along the Z axis and rocking and rolling in the heavy sea. Do I have to also animate the primitive as well? Cheers
Jaager ( ) posted Wed, 29 October 2014 at 12:58 AM
I think you should focus on the ultimate result.  What do you need the interaction between the sub and the water to look like?  What do you need a primative to do to generate that interaction?
By producing this as a series of stills, you can combine  isolated key frames and see what is happening.
Theory only, but is there an after effect program component that can produce the bow breaking foam and spray and side and stern wake as a 3rd layer?
seachnasaigh ( ) posted Wed, 29 October 2014 at 5:51 AM
     You would want the primitive to at least roughly trace the intended progress of the sub.  The idea would be that if the water material is sensitive to near-underlying mesh and intersection against a mesh, then it will render with more foam around the primitive.  If the water material doesn't do this, then the primitive would be of no use.
