Sat, Nov 9, 9:44 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 10:28 pm)
Subject: V4 M4 Shoulder Fix
ralphkramden39 ( ) posted Thu, 20 November 2014 at 8:08 AM · edited Sat, 02 November 2024 at 9:06 AM
 Hi,
I used to shop here, spent a bazillion dollars here, then a couple of years ago I logged in to discover my account had been closed - apparently, I did something to irk a moderator. This turned me off to 3D art, so I deleted all my stuff and took up a different hobby. Recently, with all the alternate render engines on the horizon, I've gotten the bug to jump back into the game, so I'm amid the arduous task of getting things up and running again. There were some products I considered essential, one of which is a V4/M4 shoulder fix sold here in the marketplace, only I do not remember what it is called or the name of the vendor who made it. I've done a marketplace search, using "shoulder", then "arm" and then "fix", but it does not come up. It was sold in three packages: one for V4, one for M4, and one for both. Anybody got an idea of what it was called?
fictionalbookshelf ( ) posted Thu, 20 November 2014 at 8:38 AM
Have you tried going through your order history and searching 'fix' or 'shoulder'? If you ordered it from here it should still be in your order history even if the product isn't available in the marketplace.
My Store & My Freebies
Allstereo ( ) posted Thu, 20 November 2014 at 9:07 AM
Hello,
A shoulder fix is available at:
http://www.renderosity.com/mod/bcs/perfect-shoulders-v4---automatic-fix/92492/
 Never see a fix for M4 shoulder.
Allstereo
ralphkramden39 ( ) posted Thu, 20 November 2014 at 9:27 AM
 Fictionalbookshelf, thanks, but when they shut off your account you no longer have access to you order history or your orders.
ralphkramden39 ( ) posted Thu, 20 November 2014 at 9:29 AM
 Allstereo, that was not the one I had in mind, but upon examination, it looks good, maybe even better than the one I was looking for. Thanks!
 Still looking for the original though, so I can fix M4.
booksbydavid ( ) posted Thu, 20 November 2014 at 11:52 AM
Was it this one?
http://www.renderosity.com/mod/bcs/?ViewProduct=77763
Santel ( ) posted Thu, 20 November 2014 at 1:42 PM
the product was called simple details. two packages, one for the gen 3s and the second for the gen4s.
DarwinsMishap ( ) posted Thu, 20 November 2014 at 2:02 PM
Corvais- I use them.  They aren't sold here any longer.
hornet3d ( ) posted Thu, 20 November 2014 at 2:03 PM
 Have you considered using V4WM (Weight Map) which is available for free at RuntimeDNA you may find you do not need the fixes anymore.  If you do try it also get the Poser Place outfitter that helps clothes fitment with V4WM
ralphkramden39 ( ) posted Thu, 20 November 2014 at 4:02 PM
 Yep, that's the one - Simple Details . Wonder why its not sold here anymore? maybe a moderator kicked the poor guy out. I did not realize weight mapping took care of things like faulty should joints. Is there a weight mapped M4?
AmbientShade ( ) posted Thu, 20 November 2014 at 5:09 PM
Mods don't do that. We only remove problem members from the forums after repeated warnings.
Products that don't sell after a certain period of time get dropped from the store.
No, there is no weight mapped M4.
ssgbryan ( ) posted Thu, 20 November 2014 at 6:53 PM
But there is nothing preventing anyone from weight mapping their M4.  And 2014 helps a lot by automating some of the steps.
WandW ( ) posted Thu, 20 November 2014 at 9:20 PM
JoePublic did a weight mapped M4 LOD that you should be able to  transfer the rig and JCMs to M4 with PP2014...
hornet3d ( ) posted Fri, 21 November 2014 at 3:39 AM
 Although not stated in this thread I believe from another thread that the OP is using Poser 2012 which I believe limits the options when it comes to Weight Mapping.  It is not an issue for V4WM but could have an impact on the other figures.
moriador ( ) posted Fri, 21 November 2014 at 6:36 PM
I use the Beautiful Bends M4 from Daz. Not cheap, when it's not on sale, and full of magnets and deformers and a billion morphs. So it's also not a small CR2. But is the best set of comprehensive fixes I've found for M4.
After that, there's Ironman13's overhaul for M4. I actually don't use it much because mostly the BB figure takes care of most of the issues (and its magnets help fit the clothes to the morphs). But it's nice to have this option.
http://www.renderosity.com/mod/bcs/i13-overhaul-m4-edition/94600/
(There's a V4 version as well)
Plus a couple of fixes that I find useful for M4
http://www.renderosity.com/mod/bcs/i13-real-belly-m4/91180/
(There's glute squish morph set for sitting and leaning poses for M4, too. And a wider range of similar fixes for V4).
If you want to go a different route, and use the morph brush to fix joints -- but don't have a clue where to start -- this tutorial isn't a bad option. But there may also be some free tuts out there you can learn from.
http://www.renderosity.com/mod/bcs/smooth-pose-tut/89823/
And, of course, there's Xameva's Perfect series for V4, the complete set of which I think is or will be on sale shortly. (They come widely recommended, and I use them almost all the time.)
For V3 and M3, alas, nothing I know of, since Corvas's fixes aren't available. The morph brush is probably your best friend here, and really if you learn to use it, it's very cool. Frustrating as hell at first, but better as you practice. But I'd upgrade to Poser 2014, if you want a better morph brush. The improvements are incredibly useful (including a tighten and loosen fit brush that is collision sensitive -- for fixing even major pokethru in a matter of seconds).
colorcurvature ( ) posted Fri, 28 November 2014 at 8:12 AM
Best technique is to fix shoulder manually.
1.) Study shoulder anatomy
2.) Study morphing techniques
3.) Get efficient
I think no off-the-shelve fix product can really stack convincingly with all the other individual morph add-ons floating around... no? Some vertices will always be off :)
moriador ( ) posted Sun, 30 November 2014 at 7:10 AM
3.) Get efficient
Absolutely. Now that I'm getting better with the morphing brush, most things are dead easy to fix. And I've started to pay close attention to flesh collisions and so on. But I still use the complete Perfect Series for V4 (when I'm not using Genesis1/2) because it means I may only have to spend a few seconds on one thing, rather than on 30 things. :)
VolcanicMink ( ) posted Mon, 01 December 2014 at 10:00 PM
 I thought Snarly had something out there for that (?)
