Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
You may have to mouse-pull it manually and keep checking it - I did that by accident once in an older version of Poser and it took me a while to figure it out. I could have just closed it and relaunched to factory state, but it had never occurred to me that I could change the size on purpose.
I have PP2014GD and have changed the size to fit my notepad text page, so I will try your specific requirements and see.
Edit: Mine wants to max the height at 932 but the width of 1002 is fine. Will mess with it some more. Could you work with the same dimensions in a smaller window?
PP2014GD seems to have a width min of 292, max 1028 and a height min of 126, max 932, so a starting point of 90 x 110 is not possible with button clicking. That x 8 gives me 720 x 880, so you would still have to use Word or whatever to increase the % size of the final render to get what you want. (It is the xxxx2 by xxx2 that is throwing me - where did you get the 2's?)
Gremalkyn, I got the 2's - those figures - from a post here in the forum about rendering to Amazon/Kindle specs. Jura11, thanks for the suggestion, but what I'm trying to accomplish is to have a working screen that is exactly the same dimensions (ratio-wise) to my render output. For example, if I set up a scene in my current document window 1149x792, then used the method you suggest, I'll only be rendering some of what is in the document window I just set up. By the way, thanks for the picture; you know what they say about the ratio of pictures to words. I'm going to try the launch to factory state, see what happens.
Okay, here's what I did and it seems to have worked - just in case someone out there somewhere, some day, has the same problem. Using Artweaver ( a free graphics program) I created a jpeg 1102x1502 (just plain white), then opened a poser window, imported the background, told Poser to match the background dimensions, and there you have it! Thanks for the inspiration, guys!
Windows 7, Poser Pro 2012
Hi,
I've always rendered according to the size of my display window, which is 1135x816 - I'm assuming that is the dimensions out of the box, because I don't recall changing it - and then when I render, I make the render larger, but use the same dimensions ratio, so that what I see on the poser window is exactly what I get in my finished render (I hope that makes sense). Anyway, I'd like to try my hand at an illustrated novel on Amazon, which call for a 9:11 ratio. How do I change that in Poser? When I go to Window - Document Window Size, it says I have to "Float Palette". I do, then I type in "1002 x 1502" and it automatically defaults to 1002 x 1050. I want a Poser window that is 1002x1502. Is that impossible.
I'm sending this from an airport, about to step on a plane. Will land in a couple of hours and hopefully someone can help me out. Thanks!
