Sat, Jan 11, 3:33 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 11 12:30 am)
Subject: Can't export DS 4.6 to Poser Pro 2014 with DSON Importer for Poser
jngzsz ( ) posted Sun, 23 November 2014 at 2:29 PM · edited Sat, 11 January 2025 at 9:07 AM
 Hello.
After installed DSON and Genesis Starter and Genesis 2, config the paths with the Content Directory Manager, I creat Poser Companion Files into content directory.
But, when open Poser Pro 2014 and load de archive, aren´t figure.
I see that archive is short, about 56 byts, more or less.,
¿What I doing bad?
Thank and excuse for my bad englis.
Redgars.
RHaseltine ( ) posted Mon, 24 November 2014 at 2:45 PM
Online Now!
The PoserCF file is just an instruction to the DSON Importer to load the DAZ Studio figure - do you have the DSON Importer for Poser installed? If you do, is the folder with the figures (My DAZ 3D Library in your Public or Shared Documents folder if you used the defaults) selected as a library folder in Poser?
jngzsz ( ) posted Tue, 25 November 2014 at 2:52 AM
 Hello. Thank you for answering.
Yes, I've the DSON Importer for Poser intallaled.
In the DS 4.7, I've configured the path  with the "Content Directory Manager" and export the scene selected with "Create Poser Companion Files".
In this panel select "Select *.Duf Files in the current folder" and the "Use this library and files extensión: Cr2".   After, in the "Supplemental Path" créate a new folder and after, in the Poser Por 2014, in the panel "Figures" add the new folder crated.
But at the viewport don't anybody.
I don't see PoserCF files any folder.
jngzsz ( ) posted Tue, 25 November 2014 at 5:15 AM
 Now, Poser Pro send a new error message: "SystemError: NULL result without error in PyObject_Call"
Amaranth ( ) posted Tue, 16 December 2014 at 8:53 AM
You do not have to create Poser companion files, just set up your scene in Poser, you don't have to create a scene DS and then create companion files.
And that DSON error most likely need to reinstall DSON, pls do it manually so you know the files go into the right folders.
Amaranth3D
