Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Just a tip to decrease save time. Carrara will render a thumb for the save with your render settings; don't know why we would need a hidef thumb, So before saving set your render settings as low as you can.
I have had several scenes where it took considerably longer; up to an hour, to render the thumb, but just a few minutes to save the scene.
How to reduce 3D Scene files. How to speed up load and save times.
https://www.youtube.com/watch?v=fTDckG40qe8
A strategy to reduce your 3d scene files, using reconciliation of shaders, textures, objects and replication.
Taking careful note not to waste (include) any of these elements in your scene file will reduce the file dramatically. (Replication being the exception. That should be used often - however - even then there are limits and consequences which I explain).
Although this tutorial is aimed at Carrara users the basic principles hold for ANY 3d software package. Remember - small is beautiful here.
more info at https://www.facebook.com/scififunk?ref=hl
