Fri, Jan 24, 6:46 PM CST
Subject: Scaling in PoserPro 2012 vs PoserPro 2014
nabob21 ( ) posted Mon, 29 December 2014 at 5:11 PM · edited Fri, 24 January 2025 at 12:58 PM
Hello,
I have recently started using PoserPro 2014 after using PoserPro 2012 for a few years and I am noticing some issues when I use the include scaling when conforming option in the parameters window. This option worked quite well for me in PoserPro 2012 but it doesn`t want to work very reliably for me in PoserPro 2014. Has anyone else encountered this issue and is there a fix for this?
Thanks for any replies.
nabob21
hborre ( ) posted Mon, 29 December 2014 at 5:54 PM
Online Now!
Have you installed the latest SR 5.1?
nabob21 ( ) posted Mon, 29 December 2014 at 5:56 PM
Hi hborre,
Yes I have the latest service releases installed.
hornet3d ( ) posted Tue, 30 December 2014 at 3:41 AM
The V4WM figure I use is scaled to a implied height of 5 foot as opposed to the standard V4, for this reason I use the scaling when conforming option a great deal and I have not noticed an issue.  I am using the Game Dev version but used 2014 a lot before that and still no issue.  There is, on occasions, some poke through but no more that a non scaled conform on a non scaled figure.
What issues are you having and is it with certain items?
nabob21 ( ) posted Tue, 30 December 2014 at 8:23 AM
Hello hornet3d,
I am using a V4 in the same manner as you. The scaling issue is not just related to one clothing item. I have used those items and successfully scaled them in PoserPro 2012 but having issues in PoserPro 2014. If I successfully scale clothing to a V4 in PoserPro 2012, save the figure and clothing in PoserPro 2012 and then open the figure in PoserPro 2014 the scaling is broken. If I open the figure in again in PoserPro 2012 then the scaling works. If I try to do the scaling just in PoserPro 2014 it doesn't work reliably at all (i.e. sometimes it does but mostly it doesn't). I have tried this with a several clothing items from different vendors all of which work in PoserPro 2012. I can make things work by manually scaling in PoserPro 2014 using the scale dials but any of my saved figures that worked before have to be redone and scaled again.
nabob21
