Sun, Dec 22, 8:16 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 20 7:20 am)
Subject: V6 does not take V6 poses. They deform her.
drifterlee ( ) posted Sat, 24 January 2015 at 7:16 AM · edited Sun, 22 December 2024 at 8:15 PM
HI: I just purchased several V6 pose sets from the RMP and this is what I get. A cracked head and gray stuff showing through V6. Does anyone know what is causing this? Thanks. See attach
file_ec5decca5ed3d6b8079e2e7e7bacc9f2.jpment. Thanks
hborre ( ) posted Sat, 24 January 2015 at 7:22 AM
Online Now!
Looks like a UV texture problem.  Did you try switching skin textures on V6?
RHaseltine ( ) posted Sat, 24 January 2015 at 8:22 AM
Yes, it looks as if the pose also includes the UV set property, which generally it shouldn't - or even full materials, if the skin has changed.
aldebaran40 ( ) posted Sat, 24 January 2015 at 10:45 AM
if you will apply the skin mat  after pose , ¿ the problem continues?
drifterlee ( ) posted Sun, 25 January 2015 at 3:49 PM
Yes, the problem continues and it does it with all the textures when I used those poses.
hborre ( ) posted Sun, 25 January 2015 at 5:28 PM
Online Now!
http://www.sharecg.com/v/73633/related/21/DAZ-Studio/UVSetterGen2-Revised-10-2014
Get this script from sharecg.com and use it to reset the character UV.  There is no reason for ordinary pose files to change the UV unless these are MATfiles to change skin textures.  The Vendor should be notified about this problem and corrected ASAP.  BTW, which products are causing you problems?
