Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 6:12 am)
Not sure what you're referring to. I made the legs shorter by using "legs longer" from Morphs++ set at a negative value. Mostly I used Morphs++ and M4 Enhanced, I was trying to reshape the hips and thighs, but it I change one of them with the Enhanced morphs I have to change the adjacent body parts to fit, and it's tricky to make them fit together while retaining the shape I want for each of them. I thought I finally got it, but I morphed him in zero pose and didn't know what would happen when I posed him. I did use some things that were intended for V4 (Vittorio male morphs) but they are set very low, and when I changed them in the bent knee pose it didn't fix it.
Looks normal in zero pose. It's Michael 4 with a lot of morphs. I suspect M4 Enhanced is the problematic set since it is so piece-y, has anybody else had problems like this?
