Mon, Feb 3, 1:14 AM CST
Subject: One Master Dial to rule them all
aldebaran40 ( ) posted Thu, 22 January 2015 at 2:09 PM · edited Mon, 03 February 2025 at 12:52 AM
As you can see I have dials that control the intensity - in this case - from displaces maps, I would like to have a Master dial to control all .what I want to do is to decrease or increase the Master dial and all those who are within them increase or decrease at the same time when I move the Master dial
It is possible that?
file_65ded5353c5ee48d0b7d48c591b8f430.jp
"...One dial to rule them all, One dial to find them,
One dial to bring them all and in the darkness bind them..."
Jaager ( ) posted Thu, 22 January 2015 at 2:37 PM
Yes, it can be done.
Poser files are text files and are easy to edit.   If a channel has key values, those values can be controlled by another dial by inserting the proper code lines.
Poser itself has a "Teaching" function that does this, but since I am used to getting at the "guts" of a file directly, I have never bothered to learn the necessary fine points wen going at it this way.
D3D Poser File Editor may have a function to assist, but I have no hands on experience using it to do what you are after.
I find it easier to just hack the controls in using a text editor and the straight Paste function in PFE.
The master dial - I would just generate using  an existing master  to provide the base structure.
aldebaran40 ( ) posted Thu, 22 January 2015 at 3:22 PM
I think I have it, I think I have it
Creating Master Parameters ( in Poser pro reference Manual ) pg 670-672
I try and tell you
Schurby ( ) posted Fri, 23 January 2015 at 8:48 AM
A lot easier using PZ3Editor from Phil here at Rendo, or EasePose Underground, I use them both.
Schurby
Schurby
aldebaran40 ( ) posted Fri, 23 January 2015 at 7:01 PM
first of all thanks  Schurby and Jaager   for the reply
Yes I done it , then I will do a mini - tuto and upload it (only use  Poser , I not have D3D or PZ3Editor or EasePose  ) , but I think  it is relatively easy when you already understand what you're doing of course.
aldebaran40 ( ) posted Wed, 28 January 2015 at 6:52 PM
As I promised:
I will create a dial that controls the value of other dials (in this case those who control the strength of displace maps, but it can be anything else) file_0777d5c17d4066b82ab86dff8a46af6f.jp
aldebaran40 ( ) posted Wed, 28 January 2015 at 6:54 PM
create a new master parameter
file_0a09c8844ba8f0936c20bd791130d6b6.jpand  I click start teaching
file_f899139df5e1059396431415e770c6dd.jp
aldebaran40 ( ) posted Wed, 28 January 2015 at 7:03 PM
after I put the value of the master dial 1 and all values of the parameters of the 8 values that control the displaces strength of 1 also
then I put the intervals of the parameter "master dial " to 0 and the 8 values of the child dials to 0 (by that I teach that when moving the master dial , modify the associated  dials )
stop teaching
file_9dcb88e0137649590b755372b040afad.jp
aldebaran40 ( ) posted Wed, 28 January 2015 at 7:04 PM
I rename the master dial
file_f2217062e9a397a1dca429e7d70bc6ca.jp
dial
aldebaran40 ( ) posted Wed, 28 January 2015 at 7:10 PM · edited Wed, 28 January 2015 at 7:14 PM
Content Advisory! This message contains nudity, profanity
let's test:
master dial = 0.000
file_903ce9225fca3e988c2af215d4e544d3.jplet's put some strength to displaces, I put the master Dial  in 1.000
file_a8f15eda80c50adb0e71943adc8015cf.jp
FUCK , it seems to she have been in the water for several hours
I put the Master dial in 0.5000
file_82161242827b703e6acf9c726942a1e4.jp
better, not perfect but you already have the idea....
The best tutorial of all time? Yes maybe :)
Allstereo ( ) posted Fri, 30 January 2015 at 10:26 AM
Hello Aldebaran40,
First of all, excellent creation. I wrote a tutorial of Poser Dependent Parametesr (See the link below). I don't know if it can be useful for you because you understand the basic of dependant parameter Editor. I am not writing Part 2 of the tutorial and I expect to deliver the tutorial in about two months.
 http://www.renderosity.com/mod/freestuff/?item_id=71136
 Good luck in your project
Allstereo
aldebaran40 ( ) posted Fri, 30 January 2015 at 1:54 PM · edited Fri, 30 January 2015 at 1:54 PM
Hello Aldebaran40,
I downloaded it and I gave a quick look, it looks very very interesting, I'll read it carefully
Thank you very much for the tutorial Allstereo
