oops. The prop that was created as a FIGURE - it worked. The other props it does not. If I open a NEW scene and bring the prop in then it does work. However it won't work on mulitple props in the same scene. Dang it. I am going to have to fix each piece by running the script and resaving it in the prop library.
Windows 10 - Poser Pro 2012 - 64Bit - 24GB RAM - 4 x 3.40 GHZ processor
Depending on which Poser you're using, isn't "show hidden parameters" an option in the parameter's pallet? (Click the triangle at the top right of parameter pallet for drop down menu.) If you check it, you see ALL hidden parameters on every item in the scene. No script required.
I am on Poser Pro 2012. I fixed all of those props. But I also notice that on HAIR props the PROPERTIES tab sometimes shows nothing. The hair renders ok but you can't turn on/off the various options on the properties tab.
Any idea how to get the PROPERTIES tab back on? The script provided earlier doesn't fix that tab. Again, this is just for HAIR.
I am building a scene using the PICK building blocks from Mindvision GDS. They contain doors, windows, floors, ceilings, etc. in various configurations so you can build a room. Mindvision GDS also provides textures.
However, on the props once loaded - the TRANSFORM dials have been replaced with move right/left, move front/back. rotate, etc. There is NO SCALE dial though.
Is there a way to add the SCALE dial ? The props are a bit too small for the regular sized Poser figures. Yes, I can scale the Poser figures down but it would be easier to scale the props instead.
And, yes, I know I can export as OBJ and them re-import and all the dials magically appear again. I was trying to avoid that. Is there anyway to re-add the TRANSFORM dial that is missing for SCALE?
