Thu, Jan 9, 3:43 PM CST
Subject: Poser Pro 2014 SR 5 10.0.5.28445 - different obj-export?
ARCHITECT ( ) posted Wed, 04 February 2015 at 9:44 AM · edited Thu, 09 January 2025 at 6:39 AM
Hello.
I've installed the last Service Release (28445) for Poser Pro 2014 this morning. After all Poser is running fine but:
When I export a poser scene as an OBJ-file and try to import that mesh into Octane 2.x I'll get a file-load-error.
Octane can't import the meshes any longer (I've had no problems using Poser 2014 SR 4)
Is there a workaround so I can import meshes again or will I have to re-install Poser SR4 again?
M.
seachnasaigh ( ) posted Wed, 04 February 2015 at 10:41 AM
     Thank you for specifying the build number. :)  Please state what OS you're running (e.g., 64bit Win7Pro).
     If you have a modeler or UV mapper program, try loading the OBJ into that app.  Does it load, or fail?
     If it loads in the modeler/mapper, then save it back out with a unique name.  Can you import the new OBJ into Octane?
aRtBee ( ) posted Wed, 04 February 2015 at 10:50 AM
 in addition: when using the Poser > Octane plugin the animation tab offers a [ Export Animation ] button which saves the Octane file itself for you.
ARCHITECT ( ) posted Wed, 04 February 2015 at 10:55 AM · edited Wed, 04 February 2015 at 10:57 AM
...thank you.
The OS is Win 8.1 Pro 64 Bit.
Ok. I've tried to import the OBJ from Poser into 3DSMax 2015 - "ungültiger Normalenindex" - Max won't load the OBJ.
After that I've imported the OBJ into UVMapper Pro 2 (no problem at all) and saved the mesh with a different name.
I could import the mesh into Octane (but with no textures)
So it's obvious that the export from Poser doesn't work properly... :-(
BTW: I'm using the standalone-version of Octane - not the plugin...
M.
seachnasaigh ( ) posted Wed, 04 February 2015 at 10:59 AM
     Got it.  I'm going to call this to the attention of a friend or two who use Octane.  I'll ask them to respond here with their results.
ARCHITECT ( ) posted Wed, 04 February 2015 at 11:06 AM · edited Wed, 04 February 2015 at 11:06 AM
...found a way to import the OBJ without fiddling around with the UVMapper...
Octane - Preferences - Geometry-Import - Load vertex normals = uncheck.
Don't know if there are any "side-effects" but it's possible to import the mesh this way.
wimvdb ( ) posted Wed, 04 February 2015 at 11:30 AM
I just checked this
If I deselect all options before exporting I can load the object fine in Octane stand alone. I do get an error if I keep the default options for export
I used stand alone 2.06 to test this with PP2014 gamedev.
I normally use the plugin, so importing objs from Octane standalone has been a long time since I did that and I do not remember which options I used at that time
Glitterati3D ( ) posted Wed, 04 February 2015 at 1:43 PM
May not help, but just to add to the conversation.......
Be sure you check what the Skinning Method is set to.  Several of the programs I use (not Octane, sadly) have a problem with Poser's Unimesh object export.
Just go to Figures>Skinning Method and make sure Poser Traditional is selected.
Like I said, may be of no use at all, but thought it was worth mentioning.
ARCHITECT ( ) posted Thu, 05 February 2015 at 2:15 AM
...thank you! :-)
