Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
was someone making an addon to get poser stuff to blender (think he was called Reddog ?)
a flurry of updates on blender kept breaking it so I dunno if he just gave up or moved on to other things .......... shame because the bits he had done worked pretty good
thread should be in archives here I guess but was a few yrs ago now
yep, that was about it.
See? That is the main issue; One company can not depend on another company.
Blender is open open S. they can do with Blender whatever they like.
DAZ can do with DS whatever they want.
SM can not depend on either of them, or you are turning out SR after SR after SR after SR, to keep up with everybody's "improvements" or changes.
Each company has its own rigging system, completely different, and can change, upgrade or update at free will whenever they feel fit to do so.
There is no, and probable never will be a "one size fits all".
And any "converter script" will probably become obsolete by the time is if finished and tested.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
"yep, that was about it.
And any "converter script" will probably become obsolete by the time is if finished and tested."
This ^^
I haven't tried it ... but I believe Cycles was the bridge between Poser and Blender. There was another one several years ago, but it couldn't keep up with the constant changes that an opensource program goes through. You might want to check it out quite a few people are using it now.
Boni
Cycles is Blender's renderer. Poser Tools was for Blender 2.5 and was by Reddog. Here's the old Rendo thread for it: http://www.renderosity.com/mod/forumpro/?thread_id=2829354
Here's a link to 3dOutlaw's Poser Export to Cycles script. Not sure if it works in recent versions of Blender. It was made during 2.64.
http://3doutlaw.com/home/?page_id=631&did=17
-----sig-----
Daz, Blender, Affinity, Substance, Unity, Python, C#
What if someone wrote a program that would let you rig a figure to work in Poser, Studio, 3DS Max, or Blender?
The closest you'll get to that is FBX import/export. It's part of Poser game dev and works decently. Last I heard Blender's FBX plug doesn't function too well and they didn't seem all that crazy about making it work, but that was a couple years back so maybe it's working better now.
You'll never be able to get a figure that works seamlessly across platforms unless those platforms are all using the same rigging system, and that usually only happens when the same company is building both platforms, but even then, not always.
And, Poser's rigging system is pretty outdated and cumbersome compared to everything else that's out there today, so we'll need to wait and see what SM does with it in the future.
But for now we do have FBX (thanks Autodesk).
Actually what i was thinking was more or less having the program "auto-convert" the rigging. Say for example you export M4 into Blender, but Blender does not support Poser's rigging system. So during the export the program would give it's best approximation of M4's rigging using Blender's rigging instead. I guess you could always make adjustments if needed.
"Actually what i was thinking was more or less having the program "auto-convert" the rigging. Say for example you export M4 into Blender, but Blender does not support Poser's rigging system. So during the export the program would give it's best approximation of M4's rigging using Blender's rigging instead. I guess you could always make adjustments if needed."
You can Re-Rig M4,V4 Dawn ,Dusk et al for any program
after importing their geometry.
For poser users the appeal of poser figures is the morphing
and ability to change clothing and textures& Hair with a single click.
The closest thing to this for a high end program is the Interposer
Pro Plugin That I am using with Maxon Cinema4D studio.
Wouldn't the creator of said app need to get permission from each company whose rigging s/he plans to implement? Doesn't sound like an easy task.
-----sig-----
bigger problem might be getting permissions off the mesh creator ;-).......... are you allowed to re rig in another app? purely for ones own use ??
here's gruffles (lol I just found him god knows how long he was in runtime)
exported with collada ~ rigging intact fully posable but could do with some tweaking here and there on weight maps (maybe does in poser too I only picked him 'cos theres no morphs ~they can cause problems for me )
As long as you're not distributing it I don't see why it would be an issue. People take figures into other apps all the time.
-----sig-----
I just want to pose the model in Blender. Be nice to be able to get the textures in there too, but one step at a time. Also, it would be nice to be able to do some animation in Poser and transfer it to blender.
When you export out from Poser, it should save an *.mtl file with it. Put the obj, mtl, and the textures the figure was saved with into the same folder. When you open the obj in Blender, it will read the mtl and pull the textures with it. The version I'm using is a paint-ready version I saved out using Blacksmith3D's Poser export settings (the skin itself is a V4 MR that I already ran through TT). -Uncheck Weld body part seams
-Check As Morph Target ( no world transformations)
-Check Include body part names in polygon groups
-Check Use exact internal names except spaces
-Uncheck remaining options
-----sig-----
I forgot Blender Render and Cycles Render texture things differently. If you're using Cycles, do the above, but under each surface select Use Nodes. Set the Surface to Diffuse BSDF > click the little ball/dot to the right of Color and set it to Image Texture. Now, since you did the obj/mtl/textures in a single folder, you can click the little picture icon and select the right texture map.
-----sig-----
Collada is included in Poser Pro. I've never had much luck getting it to work but I haven't spent a lot of time trying either. I think Poser 7+ has a sort of 'light' version, iirc.
FBX is in game dev version. I don't think it's in Poser Pro. It's purpose has always been for compiling rigs, textures, anims, etc, for exporting to game engines in whatever app you're using to build content for said engines. But you can use it to send the figure to any other app that can import FBX. But once you export a figure as an FBX file I don't think you can de-compile it to function like a normal Poser figure when you bring it back into Poser. It has to remain an FBX file.
Cycles is Blender's Open Source Physically Based Render Engine. It is not a bridge between Poser and Blender. Edit: AH! Vaskania beat me to it. :)
sure I've seen an addon at BA to swop BI mats to cycles, I never looked at it so dunno if its still around (working)
Found an updated version at the end of the thread. I'll have to give it a shot, thanks! Post is here: http://blenderartists.org/forum/showthread.php?247271-Cycles-Automatic-Material-Textures-Node&p=2831787&viewfull=1#post2831787
-----sig-----
I might work on a flow chart and post it here to see if anyone has any ideas to share or critique.
