Load figure.
Load prop and position.
Parent prop to figure head.
Save prop to library. Do not select subset. Just the prop itself.
You will be warned it is a smartprop and will be asked if you wish to save it as such. You do.
If the prop you are working with does not have a parent, when you save it cannot become a smartprop without hand editing the pp2 as pikesPit mentioned above.
I've got a basic object prop, and I am parenting it to my figures head. (internal name says "head" in the properties tab)
As I understand it, when I click the Plus symbol, and select it (in the subset), it should ask me if I want it as a smart prop (which I do), but it doesn't? If I load it, it loads Parented to UNIVERSE.
Then I go to the .pp2 file and change the word UNIVERSE to "head", and save it. I then make sure the figure is selected, and load the prop and it goes to UNIVERSE....???
How do you make a Smart Prop? This is how I read to do it... (Poser 9)
