Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 11:30 am)
"but i will take any death. "
Hi I have some very violent deaths for V4 that will work with M4
on sale for %30 off until April 30
http://www.renderosity.com/mod/bcs/?ViewProduct=94023
Video Example
These are animated pose files that install in your poser runtim.e
Animistreet actually has what you want but you will have to edit the BVH files slightly. The naming conventions are not the same as Poser's naming system. Just takes a few seconds in a text editor to fix the names.
ty. i will try this.
wolf thank you
i have used carnagie melon for other things but it didnt seen to have death. but thank you for the response.
parkdalegardener:
I am going to make a quick clip with M4 then export the bvh file. I will make a copy of the bvh which needs editing and the newly made file, open them both and compare. Then I will edit the bvh file's joint names to match the ones from the bvh I made and save the newly edited file as .bvh.
Sound about right?
**Thank you again **
I am looking for a few bvh motions. primary i would not shooting deaths, but i will take any death. i have treid animistreet. but their files did not seem rigged for M4.
any suggestions?
Thank you in advance
