Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 02 9:25 am)
ya forgot Posette and Dork
Software: Daz Studio 4.15, Photoshop CC, Zbrush 2022, Blender 3.3, Silo 2.3, Filter Forge 4. Marvelous Designer 7
Hardware: self built Intel Core i7 8086K, 64GB RAM, RTX 3090 .
You might want to contact dphoadley .. because he has a great fondness for Posette (the P4 female) he could help you more than anyone else I can think of. He has done wonderful things with her.
Boni
Poser 10 is only $70 from SM, and Purplus has boxed Poser 9 for $40.
Edit; you can get a boxed copy of Poser Debut at Amazon for $12.89.
Poser 4 is 16 years old, released in the days of Windows 98 and Mac OS 8
"Oh - the manual says that? I have never read the manual - this must be why."You might want to contact dphoadley .. because he has a great fondness for Posette (the P4 female) he could help you more than anyone else I can think of. He has done wonderful things with her.
I always said, 'Don't fix what ain't broken!' However, a remap NEVER hurt anyone!!
David, I hope you don't mind, since it seems that mouchie may not check back here I sent him/her a site mail referring them to you.
Why should I mind, my V3 Posette remap was for everybody! The truth is, even V3 herself may have benefited from that project.
Another option is to load the CR2 (Figure) or prop (PP2) into Notepad.
Look for the lines that say...
version
number 8
...simply change the number to read 4.0. It will usually now load in P4 or P4 Pro Pack without any error messages.
Note I say usually because it doesn't work all the time. As HBorre comments new stuff like Dawn won't. Also if the model uses shaders/materials and not textures, you won't see those displayed on the model.
But good news is V3 and even V4 to some extent can be used OK. Plus generally anything with standard textures works fine and it's incredibly easy to fix many texture problems In P4/PP.
As for using it why not? Dashed handy if you ever create stuff and want to ensure your model will work in most software. Make it P4 compatiable and it will, no hassles with loading it in studio, vue, max etc.
If you don't know about this site, you should... :)
http://www.posetteforever.com/
Also, I think English Bob has some V2 items...
http://www.morphography.uk.vu/downloads.html
Yamato's TenTen and some other stuff is here...
http://www.eurus.dti.ne.jp/masasi/DOWNLOAD/yamato/index.htm
Edited to make the links live
"Oh - the manual says that? I have never read the manual - this must be why."I'm grateful fr the help, but may have been less than clear. I would really like to know what characters can be manipulated within the Poser 4 program, e.g. Genesis, Vic 4, Vic 5, The Girl, Hiro (and male equivalents).
I had a later version of Poser and it's not for me. Poser 4 is intuitive and simpler by far.
As mentioned in a previous post, the DAZ Generation 3 and, to some extent, Generation 4 would work. That includes Vickie, Michael, Hiro, The Girl, Stephanie Petite, The Freak, etc. Generation 5 and above (Genesis/Genesis 2) will not work because they are weight-mapped models and are lower meshed. With the most current Poser versions, the sub-division feature can increase the mesh density thus smoothing out the roughness without sacrificing file size and application speed.
Victoria 4 does not really work in P4. I tried to beta test some products for her in P4 way back in the early days of the figure's release. All the magnets caused issues. I also found problems with the ExP morphs. Genesis, Generation 5 figures or higher from DAZ will not work in anything lower than P9. They are weight mapped and require the DSON importer which is a Python script to get them into Poser. Straight Poser4 does not have Python scripting. Python scripting was not introduced in Poser ProPack along with the set room.
Poser 8 figures and Miki3 will not work in Poser 4 because the have the spherical joint fall off rigging introduced in P8.
I don't test it, but I think adman could work in Poser 4
You can try Apollo Maximus too.
"As you discuss this remember that Poser 4 had some very strange things with it. Thumbnails were in a non-standard format as were bump maps. There are probably a whole host of similar gotcha's."
The old standard icon were in RSR format which still exit in many early content. IIRC, only Poser 7 was able to read that and the newer PNG format. And yes, bump maps had to be in .bum format and plugged into an entirely different node connection.
I believe Poser 7 was the last version that could read it. Poser Pro (Poser 4.5) was the first Poser that used PNG for thumbnails, but Poser Pro through Poser 7 could read them. Those are just two things that I recall, off the top of my head that keeps people from just using content that was not designed for Poser 4.
With the proliferation of Poser and Daz models and names could someone kindly advise me which are compatible with Poser 4? (I make no apologies for sticking with this simplest of versions.)Thanks.
