Thu, Jan 9, 5:56 PM CST
Subject: Mirror, Mirror on the Wall...
3dstories ( ) posted Thu, 21 May 2015 at 12:34 PM · edited Thu, 09 January 2025 at 5:53 PM
PPro2014 Game Developer SR5 but also previous SR from October 2014.
I have a mirror on a wall.  When characters are close to it they are reflected properly. When they get about 20 feet away they invert and become enlarged (Upside Down and bigger). I haven't figured out where the inversion point is or if it changes suddenly or gradually.
So, basically, what I see is characters close to a mirror, then table and chairs along the back wall hanging upside down from the ceiling and really zoomed in.
As far as I can tell the mirror mesh is straight, but the mesh is my higher suspect. I know this is probably not enough information for a diagnosis, but wanted to see if anyone had experienced a Poser bug before I started trying to figure out what setting, distance, mesh, etc. might be causing the problem.
Anyone hear or see anything like this?
Miss Nancy ( ) posted Thu, 21 May 2015 at 1:49 PM
you could replace it with poser plane prop, which has correct normals.
also, show yer mat room settings.
bagginsbill ( ) posted Thu, 21 May 2015 at 3:06 PM · edited Thu, 21 May 2015 at 3:11 PM
What you describe is possible with a concave geometry mirror, or a flat one with a carefully designed normal map applied. Since you didn't mention a normal map, your surface must not be flat.
If the inversion happens around 20 feet away then the radius of curvature is 20 feet. A mirror about 4 feet in height with an indentation of about 1.3 inches would produce such an effect.
3dstories ( ) posted Sun, 24 May 2015 at 10:15 AM
Two good suggestions and a method towards diagnosis. Sorry for the delay; I'm not always here.
  It is a set that I bought. The mirror looks flat, but may not be. Not sure what is meant by ' a carefully designed normal map applied.'
 I did 'borrow' the reflections material from a mirror that was working on another set so I tend to suspect the mesh here.
I'll see if I can get a screen capt of the mat room settings. I'm wondering now if I have a spherical reflection map applied someplace and it is inverting?
Also I will see if I can separate out the mirror mesh - or turn it off independently - and replace it with a poser plane prop.
heddheld ( ) posted Sun, 24 May 2015 at 11:17 AM
any poly has a normal ~ is the way its pointing ( is an average of the vertex normals ) they can be altered but its not for the faint hearted lol and I don't think poser can do it
bagginsbill ( ) posted Mon, 25 May 2015 at 8:04 AM · edited Mon, 25 May 2015 at 8:07 AM
"Not sure what is meant by ' a carefully designed normal map applied.'"
I was explaining what the circumstances could be. If I had told you the only way to get the effect you described was a curved (not flat) mirror, then I would have told a lie. There are two ways to get the effect. A curved mirror is most likely, but it is possible to do this also with a perfectly flat mirror, if you have a way to alter the normals. A normal map (or bump map but these differ only in the assembly - they do the same thing) can distort the surface of an otherwise completely flat geometry.
Here is a demonstration - the square mirror is completely flat. I am sure because I made it. It is a single 4-sided polygon, with all four vertices in the same plane. The reflections are distorted by a carefully designed normal map. In particular, it is a parabolic normal map - it mimics the curvature of a parabolic mirror.
file_8f85517967795eeef66c225f7883bdcb.jp
I'm in no way suggesting this is your situation. I included the possibility of altered normals to prevent the potential exhibition of pedantry that might have ensued if I'd made the inaccurate claim that the only possibility is a curved mirror.
Note: Your mirror geometry may indeed be flat, and the curve is being added because the edges are welded to other non-coplanar polygons and you enabled smoothing. Smoothing bends polygons into curves to make organic surfaces smooth. If you have smoothing on for the mirror, turn it off.
bagginsbill ( ) posted Mon, 25 May 2015 at 8:09 AM
Here is the same mirror with the alteration of normals removed.
file_a5e00132373a7031000fd987a3c9f87b.jp
