Mon, Jan 27, 8:14 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 25 8:29 am)
Subject: How do I import clothing poser to Daz Dynamics?
bu_es ( ) posted Wed, 03 June 2015 at 12:57 PM · edited Sun, 26 January 2025 at 4:50 PM
 Hello I have a scene in poser trying to render in Iray... But I mind the pz3 and clothes
 I get  no in position. Is there any way to import the dynamic clothes?.
LaurieA ( ) posted Wed, 03 June 2015 at 1:16 PM
The only way I know of is to run the simulation in Poser, export the clothing and the figure (posed) as object and import into DS. There is no way to use Poser dynamics in DS. Poser's dynamics and DS's dynamics are not compatible.
bu_es ( ) posted Wed, 03 June 2015 at 2:05 PM
  Thank you but would have any formqa exported in fbx or collada?
bhoins ( ) posted Thu, 04 June 2015 at 10:56 AM
What figure are you talking about? If it is a Poser7- figure (which includes Victoria 4/Michael 4 and their generation) there is a poser python script called dyn2morph which will convert the drape in each frames of your animation to a morph and set the morph correctly. Then saving it as a pz3 will allow you to just open it in DAZ Studio. (Note also works for a still.) The last place I saw the script was on CarraraCafe.
This is not a method I have tried with DSON Importer for Poser, for example, Genesis or Genesis 2 (Male or Female) so I don't know if it will work. I know it will not work with Poser figures created using Poser rigging after Poser 7, so no Roxie, or Miki 3, etc.
DarwinsMishap ( ) posted Fri, 05 June 2015 at 9:36 AM
If you want dynamics with the clothing, there is no way.  Daz uses Optitex exclusively for their dynamics, and unless you have the program (which is very expensive) you can't make dynamics work from Poser to Studio.  I would suggest using the dynamics in Poser, doing as they say and save it as a morph- or even saving the attire as an .obj and importing the already posed piece into Studio that way.
