DAZ|Studio F.A.Q (Last Updated: 2025 Jan 11 12:30 am)
For starters, it's not "L Ray", but rather iRay (it's been around since 2003) There are hardware specs at the Nvidia site as well as other info
It is not necessary to have a fancy graphics card, it can use CPU only rendering. If you have a high end graphics cards you will get slightly better performance.
I have a GTX 750, but don't use it for rendering acceleration because most scenes that I do are too large to load into card memory.
You need to have 4.8 installed, it comes with iRay gratis. You can still use 3Delight if you like because iRay doesn't support certain shader networks.
I haven't looked at any tutorials for DS, because it doesn't operate substantially different in DS that it does with any other program.
There are differences in implementaion of MDL, but that only matters if you are going to write your own shaders
There seems to be one of their learning lessons with the new Daz studio 4.8 that shows you how to find out if IRay render option is available with your video card. seems it is using the Barefoot Dance lesson that has been updated to include some basic visual steps on setting IRay IRay is not fully included with Daz long as you have the latest version. Hope this offers some help
Good luck
Lobo3433
Iray IS included with DS 4.8.
Good luck
Just to be correct, it is Iray. LOL. (Sorry I couldn't resist.) The biggest differences between 3Delight and Iray, in DS, is lighting. Since it is unbiased physically based, light it like you would light something in the real world, and set your tonemapping like you would a real world camera.
Okay, my bad, iRay, not LRay or lRay.
Thanks for the info everyone. As always though, if I go away for a while I always find myself with a big learning curve to deal with upon returning. Never really did get the hang of lighting in previous DAZ versions. It always seemed so counterintuitive to the real world, which is why I always struggled with it and the technical stuff involved that went waaaaay over my head. Which is why some good "See-Spot-Run" or "DS lighting for Dummies" tutorials would've been real helpful. I was going to try the Dreamlight tutorials, but a lot of people on these forums had bad experiences with the author and felt ripped off, so that scared me away from trying them; didn't want the same experiences. So I'll see what I can find on YouTube & see if I can make sense of "iRay."
As for DS 4.8, can we still save our renders in .BMP, or .TIF?
Mark,
A few simple tips that you might find useful.
Search out SickleYield's tutorials on DeviantArt. They're good and one of them deals with setting up your first scene.
You mentioned lighting being something of a problem. Google 'free hdri' and get the ones you like the look of. Also get the free RedSpec HDRI pack from DeviantArt.
Set up a figure in your scene with a camera. Make sure the camera is selected in the Scene tab, got to it's Parameters and turn off the headlamp. Press Ctrl-L if your viewport goes dark. Then go to Render Settings and Environment. Make sure Dome and Scene is used. Browse for an Environment Map and select one of the .hdr or .exr you got earlier (don't use jpg's as they're crap). Depending on what the HDRI is, you'll probably want to turn Draw Dome on as this will give you a background image of some kind. Render. If the light is coming from the wrong direction, use Dome Rotation to alter it until you're happy, or load another hdri.
I rarely use the normal lights now. HDRI's do the job for me but I mainly do portrait/figure stuff.
Happy rendering.
Does IRay automatically handle SSS or do I have to turn it one like in Poser?
Depends on the texture/material you have applied to the character. If you use a material built for Iray then you shouldn't need to do anything (unless you want to tweak). If it's other materials you will need to set it up and use appropriate values. But there are a couple of default materials included with 4.8 that will get you most of the way so all you need to do is tweak the settings. You can also set up your figure with a non-Iray material, ctrl-click an Iray skin material to apply it, choose ignore, and then you get those Iray settings on your current material. "How long do I have to let an IRay render run to get smooth skin? No speckles."
Speckles?? Do you mean fireflies?
It's impossible to answer. How long is a piece of string? How big is a hole?
It depends on how quick your CPU is, what you have in your scene, what you are doing in that scene in regards to lights, shadows, SSS, caustics etc etc. You could try messing around withe the render settings, change the quality, max samples, make sure the firefly filter is enabled. But if most of those are increased, then so is render time.
I've been hearing a little bit about NVidia's L Ray lighting & rendering system that supposedly works with DS 4.8 I've been away for a while and haven't had time to do any DS work in months.
a. Do I need one of the very latest like the 960-980 cards, that Titan-X beast, or one of the Pro level Quadro cards costing both arms, legs & an internal organ?
b. I currently have a relatively old GTX 770 card. Would that work by any chance? (crossing fingers)
Do I need to download additional software from NVidia afterwards? This segways into next question...
Does L Ray come installed with DS4.8 or is DS simply compatible with it and I have to pay separately for it from NVidia site somewhere?
Are there tutorial videos to help learn the use of it? And in Plain English not requiring an advanced degree.
