Wed, Jan 8, 12:38 AM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Jan 07 9:35 am)
Subject: First Project does not seem to work right with Poser Debut
RustySproket ( ) posted Thu, 18 June 2015 at 10:16 PM · edited Wed, 08 January 2025 at 12:26 AM
Hi all,
I just got Poser Debut a couple of days ago and have been working my way through the quick start info. The "First Project" starts up ok but at 5.8 when you add "the Pad" all the screens go dark except a partial section of the top view.
There are at least 9 lights scattered around so it should be lit up.
Any ideas?
donnena ( ) posted Fri, 19 June 2015 at 8:04 AM
I'm at a loss here because I don't have either Poser Debut or the first project.... so I'm guessing....
What happens when you render? (Control r)
Are all the lights black?
if you put your mouse on the camera ball and push or pull, does anything change?
Andy!
daywalker5577 ( ) posted Fri, 19 June 2015 at 8:50 AM · edited Fri, 19 June 2015 at 8:51 AM
I dont have poser debut either, i'm on ppro2012 ... but can you explain what you mean with "all the screens" ? . so it isn't just the previewworkscene that goes black?
can you post a screenshot ?
Miss Nancy ( ) posted Fri, 19 June 2015 at 12:12 PM
I don't have poser debut, but "pad" comes with all versions and is easy to use.  I've done several renders with it.
however, method is advanced.  requires either removing a wall or making camera visible and moving it inside near the origin (0,0,0) but above the ground plane.
make sure the camera isn't blocked by nor inside figure or furniture.
RustySproket ( ) posted Sat, 20 June 2015 at 9:00 AM
 Well I'm getting it. The camera was way out of range and behind a wall or something. Thanks for all the input. No telling how long it would have taken me....  :)
daywalker5577 ( ) posted Wed, 24 June 2015 at 3:31 PM
sometimes it can be something really simple :) glad you've found it :)
