Sun, Oct 6, 8:02 AM CDT
Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
Subject: New Bryce Clouds
UVDan ( ) posted Wed, 08 July 2015 at 4:57 PM · edited Sun, 06 October 2024 at 7:55 AM
Forum Moderator
I have not posted here in a while, but this is a new project I am working on.  New clouds for Bryce.  These will work in any rendering program, but this particular set is Obp for Bryce.
file_0336dcbab05b9d5ad24f4333c7658a0e.jp
SndCastie ( ) posted Wed, 08 July 2015 at 8:09 PM
looking good
Sandy
An imagination can create wonderful things
SndCastie's Little Haven
staigermanus ( ) posted Wed, 08 July 2015 at 9:25 PM
quick question: when you say it will work in any rendering program,.... what file format is required to import the set?
UVDan ( ) posted Wed, 08 July 2015 at 10:00 PM
Forum Moderator
Thanks SndCastie!  Staigermanus it is 2d jpegs with black and white transparency masks.
staigermanus ( ) posted Wed, 08 July 2015 at 10:13 PM
ah, sweet, would be interesting to turn them into volumetric 3D. We can map a bunch of such particles across the images, based on dark vs. bright elements. Then stack it up and look at it from slightly different angles. or add full twist and motion too. If you want me to try that on 2-3 Jpegs?
UVDan ( ) posted Wed, 08 July 2015 at 11:20 PM
Forum Moderator
Staigermanus I am trying to get away from having to use volumetrics.   Why I went this way in the first place.  So no I do not want to do that.  But thank you for offering.  I appreciate it.
staigermanus ( ) posted Thu, 09 July 2015 at 8:21 AM
Ah, yes I see, and it certainly adds a level of speed and flexibility. It's different.
We don't really do volumetrics either, it's particles that cover the areas in a way to mimic volumetrics. I guess you could say it's a hybrid between real volumetrics and your still images.
By-the-way, if they are in Jpeg, how do you manage to put transparency on it?  or do you rather use the same image as both the color channel (greyscale clouds) and the opacity mask?
Would you let me have a sample to play with in PD Howler? like to place it behind our mountains?
UVDan ( ) posted Thu, 09 July 2015 at 5:37 PM
Forum Moderator
I will upload one to the freestuff later on tonight or tomorrow.
UVDan ( ) posted Thu, 09 July 2015 at 5:39 PM
Forum Moderator
This one is arranged slightly differently.
file_8f85517967795eeef66c225f7883bdcb.jp
UVDan ( ) posted Thu, 09 July 2015 at 5:40 PM
Forum Moderator
Staigermanus I hand paint the greyscale transparency maps in Corel Photopaint 9.
UVDan ( ) posted Thu, 09 July 2015 at 8:24 PM
Forum Moderator
Another one.
file_85d8ce590ad8981ca2c8286f79f59954.jp
bobbystahr ( ) posted Fri, 10 July 2015 at 8:48 AM
Well theses will certainly cut render times down...good work man.
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
UVDan ( ) posted Fri, 10 July 2015 at 11:41 AM
Forum Moderator
OK here is the freebie link for the cloud shown.
file_3def184ad8f4755ff269862ea77393dd.jp
UVDan ( ) posted Fri, 10 July 2015 at 11:42 AM
Forum Moderator
Thanks Bobby!
bobbystahr ( ) posted Fri, 10 July 2015 at 5:40 PM
got it, thanks
I see a sound
UVDan ( ) posted Sat, 11 July 2015 at 1:03 AM
Forum Moderator
You are welcome.
