Thu, Nov 28, 6:54 PM CST
Subject: mesh showing in finished render!!!! help
SoulTaker ( ) posted Tue, 14 July 2015 at 4:30 PM · edited Sat, 02 November 2024 at 10:28 PM
 Hi all
i know this has been covered before, but I cannot find it.
I need some help. I have the mesh grid/pattern showing in the finished render.
as you can guess I don't want this.
its a prop and other props in the set are OK
as always any help would be welcome and thanks ahead of time
Poser pro 2014 64 bit
Winterclaw ( ) posted Tue, 14 July 2015 at 5:04 PM
Try turning off smoothing of the object in question.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
markschum ( ) posted Tue, 14 July 2015 at 6:38 PM
You can set the display properties for each item, check that you have it set for the scene property.
EldritchCellar ( ) posted Tue, 14 July 2015 at 6:47 PM · edited Tue, 14 July 2015 at 6:50 PM
Turn off smoothing or
Raise shadow min bias to .500 or above for RT shadows or
apply an additional level of subdivision or
Use depth mapped shadows.
It's polygonal self shadowing brought about by reyes aspect of Firefly, PITA. Turn off RT shadows and do an area render of a spot that is heavy with artifacts... you'll see that they're no longer there.
Edit_ sometimes turning off smoothing doesn't work as well as expected.
EldritchCellar ( ) posted Tue, 14 July 2015 at 6:56 PM
Another interesting observation regarding, Scaling of effected object has impact on the presence of said artifacts. If you scale the object to 1000 the artifacts aren't as strong. This wreaks havok with bump and displacement strength settings however.
EldritchCellar ( ) posted Tue, 14 July 2015 at 7:02 PM
Yet another observation, heavily sculpted (ala Zbrush, Mudbox, etc.) objects seem particularly prone to these artifacts, not sure why but it seems that organic form meshes with many non planar polys are particularly troublesome.
infinity10 ( ) posted Wed, 15 July 2015 at 12:11 AM
reduce displacement value further
Eternal Hobbyist
SoulTaker ( ) posted Wed, 15 July 2015 at 4:35 PM
 thanks for all the help.
I swapped the gradient bump out and that fixed it
EldritchCellar ( ) posted Wed, 15 July 2015 at 5:17 PM
Gradient bump? Did you have a normal map in there? Was the material a Poser 4/5 mat? Curious. Anyway, glad you figured it out.
