Sun, Feb 16, 5:48 PM CST
Subject: Please read :: information about my (Anthony Appleyard's) models
Anthony Appleyard ( ) posted Mon, 27 July 2015 at 12:42 AM · edited Sat, 15 February 2025 at 3:01 AM
Currently there are 253 entries which I uploaded to the Renderosity Freestuff. They are mostly CGI models, but a few of them are utilities etc.
I joined Renderosity (or whatever it was called back then) after Poser 3 came in (in 1998) and before Poser 4 came in (in 1999).
Back then, the icon representing each model in Poser's library, was in .rsr mode :: this is a leftover from the Mac computer that the first versions of Poser were developed on, and anyone submitting a model to the library had to accompany it with its .rsr icon file.
A few years later, Poser started keeping its library entry icons on .png files instead, and if it found a library entry without a .png file, it made a .png file for that entry by automatically converting any accompanying .rsr file.
In December 2006 Poser 7 came in, and it did not automatically convert .rsr library icon files to .png mode, nor did any version of Poser that came after.
As a result (with many apologies for not correcting this problem sooner), many of the older library models that I made and uploaded, still use .rsr files as library icons, and that model would show in modern Poser versions' libraries as the "no preview" "shruggy man" default image, instead of the intended icon, and Poser 7 onwards will not make a .png file from it.
Yesterday I went through all my models' download .zip files, in the copies which are on my computer, converting all contained .rsr icon files into .png files, so if downloaded they should load into modern Poser versions' libraries correctly. I then uploaded all those converted .zip files onto my website ::: please tell me about any faults.
These corrected versions can be accessed via http://larashots.com/appleyard/3d/3dthumb.htm
Re-loading all of my Renderosity freestuff entries which are thus affected, will regrettably take longer, as Renderosity keeps a local copy of all of its freestuff.
(I have no marketplace entries.)
infinity10 ( ) posted Mon, 27 July 2015 at 3:54 AM
Thanks for your hard work.  Individual users of your Poser freebies should also be able to convert their RSRs to PNGs by using P3DO Explorer's conversion pluin, or even PhilC's Poser Tool Box, was it, IIRC.  There was also a stand-alone RSR2PNG exe file, but I can't locate the source.
Best Wishes.
Eternal Hobbyist
Anthony Appleyard ( ) posted Mon, 27 July 2015 at 4:04 AM
The above caution should not apply to models which I made in the last few years, but many of my older models (whose .CR2 files are dated before somewhere around 2006) may be so affected.
rokket ( ) posted Mon, 27 July 2015 at 7:11 AM
 That's a pretty big undertaking there, Anthony; a lot of years of work. I wish you well in your endeavors and thank you for all your contributions to this art.
Anthony Appleyard ( ) posted Mon, 27 July 2015 at 9:11 AM · edited Mon, 27 July 2015 at 9:15 AM
I have finished the job. I have changed all .rsr icon files to .png in my freestuf. Please report all errors to me.
I was thinking of suggesting that someone should write a script to do this right through the freestuff -- and it seems that on 26 July 2015 about 5 pm Wikipedia time, someone already did it as I was looking through my freestuff!! judging by the dates by inserted .png files in my uploads. But I found some unconverted models,which I have now put right; and I found some corrupted models without their graphics files, and I had to put their graphics files in again in edit. And one model was badly corrupted and I had to delete it and re-upload it from scratch.
markschum ( ) posted Mon, 27 July 2015 at 12:00 PM
heres P3do and rsr converter plugin http://www.senosoft.com/download.php
or this one http://www.renderosity.com/mod/freestuff/?item_id=57197
Its handy to have the utility because there is still free stuff with rsr thumbnails. I know I have lots of old stuff that needs conversion if I have to reinstall it.
NanetteTredoux ( ) posted Mon, 27 July 2015 at 1:11 PM
This is very considerate of you. Some of the items I bought recently still had thumbnails in rsr format,.
Poser 11 Pro, Windows 10
Anthony Appleyard ( ) posted Mon, 27 July 2015 at 4:08 PM · edited Mon, 27 July 2015 at 4:15 PM
The answer is, Poser should be put back to automatically convert to .png  any .rsr library icon that it comes across, like it did up to Poser 6. Over the years I get endlessly weary of "no backwards compatibility". I sometimes write Windows software, and it was a major &()&() losing the system call function that read or wrote one screen pixel.
ypvs ( ) posted Mon, 27 July 2015 at 4:10 PM
 I've have a good selection of your models in my runtimes. Compared to the time taken to create them it's only a minor inconvenience to convert the RSR file. Many thanks
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
Anthony Appleyard ( ) posted Mon, 27 July 2015 at 4:17 PM
ypvs wrote:-
"I've have a good selection of your models in my runtimes."
What images have you made using them?
"Compared to the time taken to create them it's only a minor inconvenience to convert the RSR file. Many thanks"
But some users do not know such technicalities.
Kazam561 ( ) posted Tue, 28 July 2015 at 7:52 PM
Thank you Anthony for all your hard work. I think there might be a script at RDNA (though it could be a paid one) that also converts the RSR. It would be an excellent feature for the next version of Poser to have... or a python script for the current one to have....
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
quietrob ( ) posted Wed, 29 July 2015 at 6:54 AM
Thank you for all of your hard work and making our lives a bit easier.  I have the Rsr2png executable.  It also works on all sub folders.  If you still need it just drop me a site mail.  Again, thanks!!!
12rounds ( ) posted Wed, 29 July 2015 at 12:17 PM · edited Wed, 29 July 2015 at 12:18 PM
Just FYI, Semidieu's Library Manager Python tool meant as Poser library replacement at RDNA also automatically converts .rsr files to .png whenever it encounters them. I've never had to worry about .rsr -files again when I bought the tool many years ago.
