Fri, Feb 7, 12:15 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Subject: bumps ,displacements ,normals ?
RorrKonn ( ) posted Tue, 11 August 2015 at 7:22 AM · edited Fri, 31 January 2025 at 12:06 PM
file_76dc611d6ebaafc66cc0879c71b5db5c.jp
file_7ef605fc8dba5425d6965fbd4c8fbe1f.jp
file_42a0e188f5033bc65bf8d78622277c4e.jp
file_fc221309746013ac554571fbd180e1c8.jp
file_31fefc0e570cb3860f2a6d4b38c6490d.jp
file_6cdd60ea0045eb7a6ec44c54d29ed402.jp
RorrKonn ( ) posted Tue, 11 August 2015 at 7:33 AM
Using Poser Pro 14
I'm trying to make a mech that the polycount is not 600,000.So I need to keep the polycount low and use maps.
but the maps are not participating correctly ,as you can see.
How do I get rid of the odd shadows just using maps. with out using SubD's ?
I want just the maps 2,4 to look as good as the SubD's 3,5.
So how do we do this ?
the polycount is 1400.
1.no map
2.bumo map
3.bump map subD'd once
4.displacement map
5.displacement map SubD'd once
1,2,4 still has the low polycount shadows.
even thou 2,4 has bump maps on them.
4 is a displacement map that razes the polycount so why can I still see odd shadows on 4 ?
Does Poser Pro 14 have normal maps ? if yes ,where ?
Does Poser GameDev have normal maps ?
Thanks
RorrKonn ( ) posted Tue, 11 August 2015 at 7:35 AM
Displacement maps blows the mesh up like a balloon n makes the mesh larger.
How do you keep it from blowing the mesh up ?
RorrKonn ( ) posted Tue, 11 August 2015 at 7:47 AM
In case all my rambling didn't exsplain what I need.
I need the mesh with a polycount of 1,400 with a bump or normal map to look just as good as the same mesh with a polycount of 22,400.
seachnasaigh ( ) posted Tue, 11 August 2015 at 8:21 AM · edited Tue, 11 August 2015 at 8:28 AM
You can use a math node to subtract a bit from the displacement map.  Some areas will be sub-black (less than zero, or negative);  other areas will still be lighter than black (positive).  With a positive value in the displacement value box, this will make some areas engrave, and other areas pop out.
file_1d7f7abc18fcb43975065399b0d1e48e.PN     If you subtract 0.5 from the displacement map and then multiply by 2, you can use a map in which grey is no displacement, white is full outward displacement, and black is full inward displacement.
posneg-displacement.jpg~originalposneg-displacementDemo.jpg~original
RorrKonn ( ) posted Tue, 11 August 2015 at 5:03 PM
Thanks for the lesson seachnasaigh :)
722 ( ) posted Tue, 11 August 2015 at 5:35 PM
Poser Pro 2014 has  it is expected  in the mat room poser surface ,down to Gradient bum the greatdient mode use the tangent space.  try that
bagginsbill ( ) posted Tue, 11 August 2015 at 7:25 PM
Note:
Instead of (x - .5) * 2, you can save a node and do 2x - 1
RorrKonn ( ) posted Wed, 12 August 2015 at 8:31 AM · edited Wed, 12 August 2015 at 8:32 AM
seachnasaigh I tried to copy your 2 math functions, I never got it right.
Thanks for your alls replies and help ,but I don't get the material room very well. I need to learn it a lot better.
But you can get a mesh with a polycount of 1,400 with a bump map to look just as good as the same mesh with a polycount of 22,400 ,  right ?
I never got if Poser Pro 14 or Poser GameDev has normal maps ?
RorrKonn ( ) posted Wed, 12 August 2015 at 10:52 PM
 seachnasaigh what is the polycount of your cube you used in your render ?
EldritchCellar ( ) posted Fri, 14 August 2015 at 3:33 AM
Import your displacement maps, assuming they were exported from zbrush, into an image editor. In photoshop I use the channel mixer to make sure my middle grey is 127/127/127 on my sculpt maps. This middle grey will be 0 displacement in the material room as run through a math subtract, value 1=1.00/value 2=0.5, plug your map into value 1, plug this math node into displacement socket, season to taste.
Model using edge/ control loops, not bevels that produce tris. Beveling in this manner and just adding additional loops is a pointless exercise in futility. We already talked about this so...
The value of minimum shading rate in object properties/render settings controls the quality of displacement in regard to micropolygonal subdivision, in addition to map resolution and bit depth. Poser can utilize 16 bit maps. Minimum shading rate is globally controlled in render settings and locally within object properties, Poser will utilize the lower quality setting if for instance you have minimum shade rate set at .20 in render settings and .10 in object properties. Make sure both values match in both properties and render settings to utilize settings lower (lower settings being higher quality) than the default .20. I use a python script to expedite this process for objects as it can get pretty tedious with figures and multiple actors
Make sure your min displacement bounds is set at 1.000 in render settings, there is also a bounds setting in the object properties, wouldn't hurt to make sure that's at 1.000 also but I'm a little sketchy on this as there's a bug with Poser wherein that value will randomly change itself back to 0.000 willy nilly.
Also your display units settings in prefs will determine your displacement in relation to object scale, if your rendering a huge object with displacement and your settings are inches it won't render as expected with values that would ordinarily work on a regular, human scaled object. Use feet for giant thingies.
Just the way it is with Poser, far as I know. There aren't any shortcuts. If I'm wrong somebody please correct me.
EldritchCellar ( ) posted Fri, 14 August 2015 at 3:36 AM
Btw, a single one sided polygon will render out displacement just as detailed as a 1000 polygon plane. Mesh res is moot, displacement is a render function. Look up micropolygonal displacement.
EldritchCellar ( ) posted Fri, 14 August 2015 at 4:18 AM
Bump maps won't show in profile as will displacement, nor cast shadows. Best used for fine surface details like pores, fine hairs, etc. Not sure that using bump maps will get you the effect you're looking for. In most cases you can get away with using bump without the math subtract node (as you would with displacement), if however bump generated detail intersects (say on lips or some such surfaces in close proximity) it can cause black render artifacts.
Normal maps? Never use them... but yeah, gradient bump channel as mentioned earlier.
K, movie time while my poor computer chugs through a render.
RorrKonn ( ) posted Fri, 14 August 2015 at 6:09 AM
Thanks for the info EldritchCellar
tonyvilters ( ) posted Thu, 27 August 2015 at 10:45 AM
A displacement map does exactly what the word says. It "displaces" and it is a "map".
Displacement = It moves the texture outwards following the direction of the normals. And it depends on the units you are using in Poser.
It is a map = Pixels. => And Pixels are little squares.
So: A displacement map, displaces pixels to an amount set by the node and the units used.
To get rid of what you see you can do 2 things.
a) Reduce the amount of the displacement
b) Make the pixels smaller. => Use a larger map.
Maps can be:
512x512 => Large pixels, heavy saw tooth effect
1024x1024
2048x2048
4096x4096
8192x8192 => Small pixels, little to no saw tooth effect.
The larger the map size, the smaller the rendered pixels will be, and the smaller the saw tooth effect will become.
So?
•Reduce the amount of displacement in the node
•Blur the edges on the map
•Or use a larger size map
