Forum Moderators: wheatpenny, RedPhantom Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2024 Nov 24 8:35 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered. Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Here are some close-up, large renders of the models.
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
@4222980 Well looks like my wife was right I could't see the beauty of them until they were finished. Now I think they would not look as good without the maze, it really adds to the feel. Great vision and excellent craft work as always LuxXeon.
Merci! I follow your models, and use them in my scenes. You have the high quality of works in Freestuff of most I have used, and to this I must apprecier the gifts you present us. I made this fast render in Blender Cycles with a Daz female, and used this model of earrings on her. She was very happy to have them! I think she wants more!
Thank you all very much for the support! I'm honored that you have found these models useful. @zandar, very good render!
My Free Models
My Video Tutorials
My CG Animations
https://www.renderosity.com/mod/freestuff/cyclide-ritual-earrings-obj-version-/75592
Elegant pair of Cyclide Ritual Earrings, including a left and right object selection. The pair together contains a combined total of 18,708 polygons, and 18,584 vertices (9,354 quads per earring). The models have been carefully UV Unwrapped, without overlapping edges, to prevent texture distortion. There are no texture maps provided with this set, but each earring has 3 distinct material zones, and can easily accept any seamless, metallic procedural material, in any software render engine.
*The (POSER).obj files have been scaled to import perfectly to the fit the "Genesis 2 Base Female" character in Daz|Studio 4.x., and should import in an approximate location in Poser. See the import instructions below for detailed information on how to import the appropriate models to the software.
Models created in 3dsmax. All example renders were done with the Corona Render engine, for 3dsmax.
You are free to use or modify this model as you see fit, for your own rendering projects or scenes. As with all my freebies, the object can be used for both commercial and non-commercial renders. You may NOT, however, resell or redistribute the model or textures, or any derivative of them; individually, or as part of a package/set.
Alternatively, you can download this model from the following resource websites, which includes additional promo renders:
ShareCG.com
CGTrader.com
DAZ STUDIO USERS: The OBJ with (POSER) suffix was exported with a scale conversion that will allow the object to load with appropriate scaling into Poser 9 and above, or Daz Studio 4 and above, with Poser import preset settings. To import this file into Daz Studio, select File > Import, and find the "cyclideritual-earring_(POSER).OBJ". There is one model for the left side, and one for the right. In the OBJImportOptions dialogue box, select the Poser (1 Unit = 8 Ft) preset option in the "From:" dropdown menu. Scale should be set to 24384% automatically. If not, then please enter that value into the Scale field. Keep the Axis Conversion X=X, Y=Y, and Z=Z, with NO checkboxes in the Invert Direction options. Be sure Read Groups, UV Coordinates, Surfaces, and Material Library (.mtl) are all checked. The objects are designed to import in place on a default Genesis 2 Female character, in the default T-Pose position in the scene. Simply parent the earrings to the character's "head" node, once they are in position.
As with all my products, I stand behind my work. If you find any problems, or have a hard time using these models, please let me know.
My Free Models
My Video Tutorials
My CG Animations
