Sat, Feb 1, 4:49 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Jagged Displacement Maps
arrowhead42 ( ) posted Wed, 26 August 2015 at 11:27 PM · edited Sat, 01 February 2025 at 4:41 AM
Hi, I've recently begun playing around with displacement maps to achieve different effects, and I came across an issue which is troublesome.
I made a displacement map which corresponds to a texture map, both of which represent a leather strap on a uniform. The displacement map defaults to a value of .0833 when I install it in Poser's material room, and from a distance, renders perfectly. I think it looks great! But a close up render shows the edge of the strap being all jagged. I've attached a pic of the rendered strap, plus the corresponding material room settings. Is there a way to adjust some settings and make he edge of the strap look smooth?
Thanks
Here's the link to my freebies:   https://www.renderosity.com/mod/freestuff/?uid=493127
My cousin Jack can speak to beans. That's right.... Jack and the beans talk
3DFineries ( ) posted Thu, 27 August 2015 at 5:35 AM
I've been messing around with Displacement maps for a few weeks now and had the same problem. There are a couple of things you can do. Either lower the value of the node OR open your map in your image editor and copy the layer, then blur the copy & put it under the original map. Copy the layer you just blurred, blur that layer and put it under both layers, then repeat until you have a nice smooth transition. I typically use 3-5 blurred layers. Blurring layers will create a bit of a smoother transition. :)
Have a creative day!
My Lil' Store
hborre ( ) posted Thu, 27 August 2015 at 8:36 AM
Clearly your displacement value is too high. What type of units is Poser using as a default? That will determine your displacement value. I have mine set to inches. Also, if you have the most current version of Poser, set your filtering value to crisp rather than quality.
And just a formality, uncheck the Reflection_Lite_Multi, it does nothing improve your render in this instance.
tonyvilters ( ) posted Thu, 27 August 2015 at 10:40 AM
A displacement map does exactly what the word says. It "displaces" and it is a "map".
Displacement = It moves the texture outwards following the direction of the normals. And it depends on the units you are using in Poser.
It is a map = Pixels. => And Pixels are little squares.
So: A displacement map, displaces pixels to an amount set by the node and the units used.
To get rid of what you see you can do 2 things.
a) Reduce the amount of the displacement
b) Make the pixels smaller. => Use a larger map.
Maps can be:
512x512 => Large pixels, heavy saw tooth effect
1024x1024
2048x2048
4096x4096
8192x8192 => Small pixels, little to no saw tooth effect.
The larger the map size, the smaller the rendered pixels will be, and the smaller the saw tooth effect will become.
So?
  • Reduce the amount of displacement in the node
  • Blur the edges on the map
  • Or use a larger size map
Miss Nancy ( ) posted Thu, 27 August 2015 at 11:15 AM
you can also try incr. to 16-bit greyscale.
arrowhead42 ( ) posted Sat, 29 August 2015 at 1:09 AM
Wow! This really worked well! I blurred the map and lowered the displacement value and I think it turned out great, Take a look - thank you all so much!Jagged2.jpg
3DFineries ( ) posted Sat, 29 August 2015 at 6:49 AM
Looks much, much better! Glad all the advice helped. 😉
My Lil' Store
Boni ( ) posted Sat, 29 August 2015 at 3:14 PM
For future projects and those of you also looking into this, sometimes using a blend of displacement and bump can offset exaggerated effects like this.. Just another approach ... I have used this with skin and sclera maps.
Boni
Boni
