Sat, Feb 8, 7:40 PM CST
Subject: GPU and CPU Firefly render
xpdev ( ) posted Mon, 07 September 2015 at 1:40 AM · edited Sat, 08 February 2025 at 5:15 PM
Hi
I am planning to switch to use Octane to render in Poser.
I would ask for a clarification.
Poser engine render uses the CPU - No way to use GPU Firefly engine render uses the CPU - No way to use GPU
Octane engine render uses the GPU
Am I right or wrong?
Thank you.
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
acrionx ( ) posted Mon, 07 September 2015 at 2:21 AM
I believe you are right. In the past when I asked this, that's the response I got.
www.acrionx.com | My Freebies | My Store | My Youtube Channel
xpdev ( ) posted Mon, 07 September 2015 at 2:24 AM · edited Mon, 07 September 2015 at 2:24 AM
Thanks.
acrionx, are you using Octane now ?
-Timberwolf- ( ) posted Mon, 07 September 2015 at 2:36 AM
You'll need the Octane render stand alone version, in order to use the Poser-OctaneRender plug-in. Yes, it is using the GPU.
xpdev ( ) posted Mon, 07 September 2015 at 3:26 AM
OK, thanks again.
There are texture limitation from poser ?
-Timberwolf- ( ) posted Mon, 07 September 2015 at 3:39 AM
Not an expert, so I think, with the latest updates, Octane switches to system RAM, when the Graphic-card RAM is not enough. This could result in longer render-times. Best is, you fight yourself through this forum: https://render.otoy.com/forum/viewforum.php?f=45 face_off is allways very helpful. :)
Plutom ( ) posted Mon, 07 September 2015 at 6:41 PM
https://home.otoy.com/render/octane-render/demo/
Read this before you purchase Octane Jan
