Thu, Jan 2, 8:26 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 02 3:53 pm)
Subject: Texture Problem
romangirl ( ) posted Tue, 13 October 2015 at 12:41 PM · edited Mon, 30 December 2024 at 9:42 PM
Here is an old p6ce garbage truck I'm trying to put in a scene. I can't change the body to a normal texture. Can anyone help? Thanks!
bagginsbill ( ) posted Tue, 13 October 2015 at 2:03 PM
Turn on Normals_forward in the advanced materials. Depending on how the shader is built, might be more than one place.
EldritchCellar ( ) posted Tue, 13 October 2015 at 2:22 PM · edited Tue, 13 October 2015 at 2:22 PM
Ot, but Bagginsbill... would you suggest normals forward for transmapped hair?
bagginsbill ( ) posted Tue, 13 October 2015 at 5:39 PM
Hmm - depends on the shader and maybe on which version of Poser. If you're using translucence maybe not. I honestly can't remember all the variations any more.
EldritchCellar ( ) posted Tue, 13 October 2015 at 5:53 PM · edited Tue, 13 October 2015 at 5:54 PM
Ok, thanks for the reply. The only reason I ask is because of the fix for rendering certain one sided transmapped plant models. I've noticed some weirdness similar to the above occassionally when rendering older hair models with idl (with texture filtering disabled, no translucence, fall off 0). I'll have to test out normals forward and see the results. Thanks
Morkonan ( ) posted Tue, 13 October 2015 at 8:13 PM
Is the model all in tris? Probably a straight export from 3DSMax, triangularized. If forcing "normals forward" in material settings doesn't work, try minimizing or disabling ray-tracing. Also, disable displacement during testing, in case of double-sided polys or split vertices.
romangirl ( ) posted Wed, 14 October 2015 at 11:39 AM
Thanks, all!
