Mon, Jan 13, 2:34 PM CST
Subject: Noob problem importing .obj into Vue 8 Xstream
muddy_chickn ( ) posted Thu, 11 March 2010 at 10:33 PM · edited Mon, 13 January 2025 at 2:23 PM
Sorry if this has already been brought up....
I just got Vue 8 Xstream and when I import an .obj, I get the object but not the textures.
The main thing I'm trying to import is some of the castle creator buildings for Poser.... but I can't get any .obj to import with textures.
Thanks for any help
R.P.Studios ( ) posted Thu, 11 March 2010 at 10:57 PM
Vue opens pz3. files, why not try that direction ?
I'd rather be hated for who I am, than loved for who I am not.
lindans ( ) posted Fri, 12 March 2010 at 3:13 AM
Check the transparency tab I think I had this problem on some items and I noticed that the transparency maps came in at 0 instead of 100per cent( or the other way around LOL!! can't quite remember now!!!
Oh, let the sun beat down upon my face. I am a traveler of both time and space ....Kashmir, Led Zeppelin
ShawnDriscoll ( ) posted Fri, 12 March 2010 at 4:37 AM · edited Fri, 12 March 2010 at 4:39 AM
Quote - Sorry if this has already been brought up....
Thanks for any help
OBJ gives more manual control of how Poser models are rendered in Vue than importing as PZ3.  So Vue needs to have the JPG/BMP maps from Poser re-applied manually to the OBJ model as texture map materials.
gillbrooks ( ) posted Fri, 12 March 2010 at 8:23 AM
I have the Castle Creator set but they are in 3ds format, not obj.
I already have them saved as .vobs as I've had the set for years, but I did just retry loading one of the 3ds parts into Vue 8 and it came in with textures applied without any problems.
Make sure you have all the texture maps in the same folder as your objects - that could be the cause of your missing textures?
Gill
R.P.Studios ( ) posted Fri, 12 March 2010 at 1:52 PM
Not that it is relevant, but i am an avid Vue/Cinema 4D user, and i have given up on Poser long ago. I do however use DazStudio for ALL my exporting needs. all the materials export perfectly with the shown settings, and the maps are all collected in one conveniant place for resizing if necessary. This is all i use DazStudio for, but it is free so it is well worth it. And it took Poser completely out of the equasion.
bruno021 ( ) posted Sat, 13 March 2010 at 2:16 AM
If you export in obj from Poser, make sure Poser writes the .mtl file (material library), if Vue doesn't detect the mtl file, it won't find the textures. This is also valid for any obj export from any package.
estherau ( ) posted Sun, 25 October 2015 at 5:37 AM
An mtl file does get created by exporting .obj from poser but when I import the .obj, vue doesn't ask for the mtl file and the object comes into vue as black.
MY ONLINE COMIC IS NOW LIVE
ShawnDriscoll ( ) posted Sun, 25 October 2015 at 6:15 AM
Not all OBJ formats are the same, unfortunately. I have to tell Vue 9.5 where my texture maps are if I'm not exporting OBJ from 3D-Coat.
estherau ( ) posted Sun, 25 October 2015 at 6:20 AM
I tend to make big poser scenes with a lot of textures so locating them all would not be a viable option for me.
ShawnDriscoll ( ) posted Sun, 25 October 2015 at 6:23 AM · edited Sun, 25 October 2015 at 6:26 AM
I think the only way I get Vue to use my Poser textures is when I import PZ3 into Vue. I'm using Poser 6 with SkinVue Elite.
estherau ( ) posted Sun, 25 October 2015 at 6:30 AM
Yes that used to work for me too. sometimes you wonder why you upgrade hey?
