Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 02 2:40 am)
AmbientShade posted at 6:50PM Fri, 20 November 2015 - #4239892
What exactly is meant by "external library" ? I thought it meant undocking the library from its default spot and moving it to another screen. Is this not the case?
The external Library in Poser 2014 was run in a separate process, it was more than just undocked.
bhoins posted at 8:57PM Fri, 20 November 2015 - #4239896
Yep. You had the option in the edit>preferences> library tab to have the library in a separate process. That's no longer the case in P11.
Boni posted at 9:38AM Mon, 23 November 2015 - #4239986
Actually you can run the library from your browser if you prefer. Most use it inside of Poser though.
This sounds cool, is this found in the poser guide? I would be interested in figuring out how to do this as might be able to actually easily grab or modify the scroll bars.
Jules53757 posted at 8:06PM Tue, 24 November 2015 - #4240632
Open IE and open the file : Your parth/Poser 2011/Runtime/ui/Flex/LSMGUI/bin-release/LSMGUI.html and the library shows up.
Ulli
I tried this, but it opens a Fault detected window. Chrome will not open it either.
Jules53757 posted at 5:54PM Wed, 25 November 2015 - #4240821
It only works with the IE and, only open the html file
I located the html file, tried opening with IE 11, but it does not open. I guess I shall merely experiment with Poser11 and wait to do serious work when SM gets around to making a service release.
It would be useful to get confirmation that I'm not the only one experiencing these before I report a bug to SM.
Library interface unusable with DSON imported assets. This was also a problem with the embedded library in previous versions of Poser, but you could get around it by using the external one. But since there's no external library in P11....?
Serious memory leak when using morph brush for an extended period. I noticed that, after morphing a dynamic dress prior to simulation, and then morphing it some more after, that a scene with Pauline, a bench, and a dynamic dress was using 5.5 GIGS of memory. After I saved the scene, closed Poser, and then reopened the scene it was back down to a very reasonable 680 megs.
This used to happen with PoserPro 2012 all the time, but it was fixed in PP2014. If I'm not the only one, it seems like a fix is in order for P11.
