Sat, Feb 1, 4:54 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Possible Poser 11 bugs. Can anyone confirm?
moriador ( ) posted Fri, 20 November 2015 at 1:58 PM · edited Sat, 25 January 2025 at 4:18 PM
It would be useful to get confirmation that I'm not the only one experiencing these before I report a bug to SM.
  1. Library interface unusable with DSON imported assets. This was also a problem with the embedded library in previous versions of Poser, but you could get around it by using the external one. But since there's no external library in P11....?
  2. Serious memory leak when using morph brush for an extended period. I noticed that, after morphing a dynamic dress prior to simulation, and then morphing it some more after, that a scene with Pauline, a bench, and a dynamic dress was using 5.5 GIGS of memory. After I saved the scene, closed Poser, and then reopened the scene it was back down to a very reasonable 680 megs.
This used to happen with PoserPro 2012 all the time, but it was fixed in PP2014. If I'm not the only one, it seems like a fix is in order for P11.
Boni ( ) posted Fri, 20 November 2015 at 2:10 PM
moriador: I've brought this to SM's attention. Just to check it out. Thank you for pointing this out.
Boni
moriador ( ) posted Fri, 20 November 2015 at 2:12 PM
Boni posted at 12:12PM Fri, 20 November 2015 - #4239818
Thanks, Boni. You're a star! :)
AmbientShade ( ) posted Fri, 20 November 2015 at 7:30 PM
What exactly is meant by "external library" ? I thought it meant undocking the library from its default spot and moving it to another screen. Is this not the case?
bhoins ( ) posted Fri, 20 November 2015 at 7:51 PM
AmbientShade posted at 6:50PM Fri, 20 November 2015 - #4239892
The external Library in Poser 2014 was run in a separate process, it was more than just undocked.
moriador ( ) posted Fri, 20 November 2015 at 10:57 PM
bhoins posted at 8:57PM Fri, 20 November 2015 - #4239896
Yep. You had the option in the edit>preferences> library tab to have the library in a separate process. That's no longer the case in P11.
Boni ( ) posted Sat, 21 November 2015 at 6:06 AM
Actually you can run the library from your browser if you prefer. Most use it inside of Poser though.
Boni
dilong ( ) posted Mon, 23 November 2015 at 5:11 AM
I can confirm. After importing DSON objects of libraries, it ceases to function. Do not import anything from the library. Only help: Restart Poser and open the file again - but only to next reuse library.
wscottart ( ) posted Mon, 23 November 2015 at 9:39 AM
Boni posted at 9:38AM Mon, 23 November 2015 - #4239986
This sounds cool, is this found in the poser guide? I would be interested in figuring out how to do this as might be able to actually easily grab or modify the scroll bars.
Connatic ( ) posted Mon, 23 November 2015 at 6:16 PM
How do you open P11 Library from the browser? Since I am getting this same problem, I would like to try running Library externally. I always used that option in the last few versions. It worked, and it was out of the way.
Jules53757 ( ) posted Tue, 24 November 2015 at 2:08 AM
Open IE and open the file : Your parth/Poser 2011/Runtime/ui/Flex/LSMGUI/bin-release/LSMGUI.html and the library shows up.
Ulli
Ulli
moriador ( ) posted Tue, 24 November 2015 at 4:36 AM
Sweet! Thanks for that.
Connatic ( ) posted Tue, 24 November 2015 at 8:10 PM
Jules53757 posted at 8:06PM Tue, 24 November 2015 - #4240632
Ulli
I tried this, but it opens a Fault detected window. Chrome will not open it either.
Jules53757 ( ) posted Wed, 25 November 2015 at 1:51 AM
It only works with the IE and, only open the html file
Ulli
Connatic ( ) posted Wed, 25 November 2015 at 5:57 PM
Jules53757 posted at 5:54PM Wed, 25 November 2015 - #4240821
I located the html file, tried opening with IE 11, but it does not open. I guess I shall merely experiment with Poser11 and wait to do serious work when SM gets around to making a service release.
