Tue, Jan 21, 2:58 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Subject: Poser 11 Physical Surface
chris1972 ( ) posted Fri, 27 November 2015 at 12:43 AM · edited Wed, 08 January 2025 at 1:41 AM
I must be getting old and stupid, I have researched the web, but the answer alludes me. Where within the Poser 11 Physical surface root node does one account for ambient occlusion
tonyvilters ( ) posted Fri, 27 November 2015 at 5:23 AM
Hello Chris,
Why would you like to add an AO to the PhysicalSurface? It does not need AO.
AO is an ol style cheat from the period before IDL+GC. (in fact, when rendering with IDL, AO is ignored) And SuperFly is a true PBR render engine, does all light calculations inside, and does not need nor uses AO at all.
chris1972 ( ) posted Fri, 27 November 2015 at 9:34 AM
Thanks for the reply, I purchased recently Algorithmic Live and from everything I have read when using IDL, AO becomes ever more important, I'm getting old and having trouble keeping up with the constant changes
tonyvilters ( ) posted Fri, 27 November 2015 at 9:50 AM
Hi Chris
In Poser10 and PP2014 => When rendering with IDL, all AO nodes on light are ignored, because the ambient occusion is calculated inside the IDL calculations.
In Poser 10 and PP2014 => Rendering WIHOUT IDL? => Then you need the AO node on the lights.
For PBR render engines (like SuperFly) all ambient occulsion calculations are done inide. => That is why there is not a slot to load an AO node.
Best regards, Tony
chris1972 ( ) posted Fri, 27 November 2015 at 9:55 AM
Thanks, I appreciate the info
Nagra_00_ ( ) posted Fri, 27 November 2015 at 10:03 AM
In case you refer to the AO slot in the FireFly root node used with IDL for light transmitter. There is a emission node for that in PBR.
Nagra_00_ ( ) posted Fri, 27 November 2015 at 10:27 AM
i meaned the ambient slot.. pressed return without reading my post;)
tonyvilters ( ) posted Fri, 27 November 2015 at 3:44 PM
Ah, no.
=> Ambient occlusion is diffusing existing incoming light back into the scene.
=> The Ambient node "adds" light. => That are 2 completely different things.
Say, I have a light that shines on an object. The object absorbs some of the light and diffuses the rest back into the scene. => That is ambient occlusion when 2 objects are close together.
The ambient node "adds" light and can be used to make TV- or Computer sreens emit "new" light. Or to make Neon lights emit new light.
But : Read this : If you have a nonsensical material, such as using the old AO node, Superfly will ignore that node when it renders; after all, Superfly inherently takes AO into account, so using the old Firefly cheat doesn't make sense.
ironsoul ( ) posted Sat, 28 November 2015 at 2:26 AM · edited Sat, 28 November 2015 at 2:27 AM
Hello Chris
Algorithmic do use AO but as an input to their smart material generator and is baked into the materials when exported.
For a new project I load the obj and then select the bake function which will generate the AO map for me. The smart materials will automatically pick up the map.
BTW - Christophe Desse's channel on Youtube is worth a visit if you're interested in seeing practical demos of using Substance Painter/Designer.
chaecuna ( ) posted Sat, 28 November 2015 at 2:30 AM
chris1972 posted at 9:29AM Sat, 28 November 2015 - #4241187
Important when you are baking textures not when you are rendering with an engine that does global illumination and not just fakes it.
