Fri, Jan 3, 6:43 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 02 11:49 pm)
Subject: Poser 11 Pro
radioham ( ) posted Sun, 29 November 2015 at 4:37 PM · edited Wed, 04 December 2024 at 4:56 AM
Hello every one My Poser 11 Pro fell down I have been on the Smith Miro Help page to find away to solve it the only thing I have found is underSolving weird issues with Poser by removing the preferences Page But where do I find the Preferences files with in Poser I have tried to print the page to show what I am on about but I just fail at that
Many thanks for the help
hopeandlove ( ) posted Sun, 29 November 2015 at 9:37 PM
Hi Radioham- let me post this in the poser forum to see if someone can help you out!
Hope Kumor
Editor-in-chief of Renderosity Magazine
cspear ( ) posted Mon, 30 November 2015 at 7:43 AM
The prefs will be in C:Users [USERNAME] AppDataRoamingPoser Pro11
Folders in this path may be hidden, so unhide if you need to.
PoserPro 11 - Units: Metres
Adobe CC 2017
radioham ( ) posted Mon, 30 November 2015 at 9:15 AM
Many thanks but it did not solve my issue..... I tried an full re-install that did not work for me I am running windows 7 Pro my Poser 2014 still runs just my Poser 11 PRO Now it dose start up but I can't access my Lib .... When my daughter is here to night I will ask her to have an look....Meanwhile many thanks Cspear for the try
Ian///Radioham
WandW ( ) posted Mon, 30 November 2015 at 10:53 AM · edited Mon, 30 November 2015 at 10:54 AM
Online Now!
Make sure your content is installed, because when I ran the program installer from DLM, it only installed the program, but not the content, which I had to install individually.
If the Library isn't showing you probably need to allow Poser in your firewall setting; the Poser library uses your computer's loopback address to connect to the main program.
If you have the Adobe flash plugin installed in your web browser, you can check by going to your Poser 11 directory/runtime/ui/Flex/LSMGUI/bin-release/LSMGUI.html while Poser 11 is running and it should open the library in your web browser. If it doesn't open the Library, it's almost certainly a firewall setting..
hborre ( ) posted Mon, 30 November 2015 at 1:20 PM
Just a silly question, did you restart your computer after installing P11? Otherwise, I agree with WandW, check internet restrictions through the firewall. Content doesn't matter; I installed Poser 11 Pro and checked it while my content downloaded for the night. Everything appears in order, ATM.
RedPhantom ( ) posted Mon, 30 November 2015 at 1:53 PM
Site Admin Online Now!
Is your internet explorer up to date? You need 9 or later. Many, though not all, I've seen having library problems it was because of that.
radioham ( ) posted Mon, 30 November 2015 at 2:41 PM
Well my hair is now grey going white at the speed of light I have un-installed every reference to Poser 11 pro in all my drives... re-installed the lot to my C: drive took awhile but it now works not just as good as I want to.... Keeps coming up stateing that Python is not loaded.... I can live with that.... Many thanks for every one's help don't think my hair will go back to grey but I can always use Painter to colour my photos
Ian //// Radioham
-Timberwolf- ( ) posted Mon, 30 November 2015 at 5:00 PM
cspear posted at 11:57PM Mon, 30 November 2015 - #4241584
So why don't I have the choice, where to install the pref-folder? Can't software companys just keep their fingers from my c-drive? They could at least ask, where to install. This isn't 1995 anymore. Man, that sucks.
radioham ( ) posted Tue, 01 December 2015 at 8:27 AM
Still don't know what happen the Lib folder stop stopped... then went super large could not gain access to it An full new install fixed it this time but many thanks for you're input
putrdude ( ) posted Tue, 01 December 2015 at 12:25 PM
This is just a shot in the dark, but windows is funky with some programs as far as permissions. Did you install as administrator? Are you logged in when you use poser as an administrator. Check the directories. I had a program that had to be installed in a sub sub directory or it wouldn't work properly.
radioham ( ) posted Tue, 01 December 2015 at 5:02 PM
What I think is in simple terms... 3D programs stopped being Windows after they stop support the great 3D Studio which was an DOS only program I think that all 3D programs now days are made for the Apple Mac then ported over to windows to open their market more.... Most music programs that I use now days are the same... made for Apple then ported over..... Now my daughter hates to see me on my lap top the 3D programs drive her mad.....she is an computer programer her boy friend is an T3 quite high up and he just says they are an mess
putrdude ( ) posted Tue, 01 December 2015 at 5:15 PM
In another post a user with problems solved his problem by giving his content directory new permissions, possibly changed in a windows update. Just a thought.
-Timberwolf- ( ) posted Tue, 01 December 2015 at 10:11 PM
WandW posted at 5:05AM Wed, 02 December 2015 - [#4241606](#msg4241606
Tried to open the library in a web browser. The result was a blue screen crash. So every time the library get accessed, it ends up with a blue screen.
WandW ( ) posted Wed, 02 December 2015 at 7:20 AM · edited Wed, 02 December 2015 at 7:24 AM
Online Now!
-Timberwolf- posted at 8:02AM Wed, 02 December 2015 - #4241922
I just opened it in both Firefox and IE and it opens fine. Flash version is 16.0. r0; I should update it...OK, works with the latest Flash version in Firefox. I'd make sure IE is fully updated.
The Adobe Air version works for me too; /runtime/ui/Air/LSMGUI/LSMGUIAIR.exe
As far as preference file location, that is a 'feature' of windows. However, you can easily change the location of most user folders, including the folders in the c:/users/[USERNAME]/AppData folder to another drive (don't be put off by the title; it shows how to do it correctly!)...
http://www.zdnet.com/article/dont-move-your-windows-user-profiles-folder-to-another-drive
Finally, I just saw over at RDNA that at least one user is having a problem with Windows 10 ver 1511 and PP2014...
-Timberwolf- ( ) posted Wed, 02 December 2015 at 7:32 AM · edited Wed, 02 December 2015 at 7:36 AM
thank you WandaW :) I ran WinDbg. Analysed bluescreen. WinDbg result is: "Probably caused by : tcpip.sys ( tcpip+62c9e )" What does this mean concerning Poser? Tried to open "/runtime/ui/Air/LSMGUI/LSMGUIAIR.exe" . I got this: Air_screenshot.jpg Is this normal?
-Timberwolf- ( ) posted Wed, 02 December 2015 at 7:45 AM
I have Poser11 since 11-11th and it worked fine until 11-30th. Now, all of a sudden, there was no library on start up and after a few seconds this session ended in a BSoD. I am thinking of an unproper automatic IE or Adobe Software update, that caused this error, but not sure - just guessing. Windows7Pro_SR1 IE11_updated 01-12 !!!
hborre ( ) posted Wed, 02 December 2015 at 8:17 AM
Sounds like the IE11 update may still be causing problems. It was like that with Poser 10 and PP2014 with the workaround reverting to the previous IE version and blocking the update.
-Timberwolf- ( ) posted Wed, 02 December 2015 at 8:21 AM · edited Wed, 02 December 2015 at 8:27 AM
Because I never use IE, I didn't care for updates - forgot to uncheck the automatic update function. Can't be the IE. Latest install is from august2015, so it whould be Adobe Air then.
WandW ( ) posted Wed, 02 December 2015 at 8:33 AM
Online Now!
I updated the 25th and no new Windows updates for me today. However, I'm using Internet Explorer 10.
The Air message may indicate a firewall issue; could be an antivirus or IE update...
http://forum.runtimedna.com/showthread.php?75418-Library-Error-No-content
https://forums.avg.com/ww-en/avg-forums?sec=thread&act=show&id=175975
-Timberwolf- ( ) posted Wed, 02 December 2015 at 11:09 AM
WandW posted at 6:07PM Wed, 02 December 2015 - #4241991
Made some settings on my firewall, now the library is clear - only in an external browser, but my system crashes instantly after this.
-Timberwolf- ( ) posted Wed, 02 December 2015 at 11:29 AM
O.k , can't handle this anymore. something change on my system and I don't know what. Can't use Poser anymore. Not any version. It's like someone painted something on the road, so my car doesn't work anymore. Unable to find a workaround. Thank you for your tips, but none of them worked.
chaecuna ( ) posted Wed, 02 December 2015 at 12:31 PM
You might verify that Internet Explorer is not in Offline Mode: on my box the Pro2012 external library gives an error message and does not work in that case, I have to put IE back into Online Mode to have it work.
-Timberwolf- ( ) posted Wed, 02 December 2015 at 1:00 PM
chaecuna posted at 7:59PM Wed, 02 December 2015 - #4242021
how to set IE to OnlineMode?
chaecuna ( ) posted Wed, 02 December 2015 at 3:05 PM
In my version it is an option in the Tools menu.
-Timberwolf- ( ) posted Thu, 03 December 2015 at 7:49 AM
BSoD seems solved. IE has done an automatic update, but win7 had not yet. Since I allowed Win to do an update, I didn't get any more BlueScreens. The Poser Library in P11Pro still doesn't work.
Jules53757 ( ) posted Thu, 03 December 2015 at 2:10 PM
-Timberwolf- posted at 9:06PM Thu, 03 December 2015 - #4242177
The error message looks like you first started with the IE and then started Poser, try it in the other way. When I start the IE, I usually don't use this, without Poser running, I get an similar Error message. In my IE I added the LSMGUI.html as the starting page.
Ulli
-Timberwolf- ( ) posted Thu, 03 December 2015 at 2:46 PM
It needed a complete uninstall and reinstall of Poser after the win update to make Poser library work. Yes, NOW it works. Finally.
Mason41 ( ) posted Wed, 10 August 2016 at 1:35 AM
I had to roll back ie to 10. Its ie 11 that not only crashed poser 11 pro for me but steam updates.
